Page 1 of 1
Axis M1031-W Network Camera
Posted: Sun Jun 27, 2010 7:03 am
by JungleGeorge
I am trying to setup an Axis M1031-W Network Camera.
[General]
Source = Remote
[Source]
Remote Protocol = HTTP
Remote Method = Simple
Remote Host Name = user:pass@192.168.43.84
Remote Host Port = 80
Remote Host Path = /mjpg/video.mjpg
Remote Host SubPath
Remote Image Colours = 24 bit colour
Capture Width (pixels) = 640
Capture Height (pixels) = 480
But in the Console screen, the Source 192.168.43.84 is red in color.
How can I fix this?
Posted: Sun Jun 27, 2010 8:33 pm
by kingofkya
Whats in zm logs?
Also did you set shared mem?
Posted: Sun Jun 27, 2010 9:51 pm
by JungleGeorge
kingofkya wrote:Whats in zm logs?
I started with the shared mem.
Added these 2 lines to the "/etc/sysctl.conf " file.
kernel.shmall = 134217728
kernel.shmmax = 134217728
Restarted the system.
Now the Source
192.168.43.84 is green in color.
Also, looking into the logs.
Thanks, kingofkya.
Posted: Sun Jun 27, 2010 10:39 pm
by JungleGeorge
So right now, I only have one monitor for this Axis M1031-W Network Camera.
When I click on the name of this monitor, the new window pops up with
the video stream and the event table below it with the Id, Name, Time, Secs, Frame, Score.
All that is fine.
But between the video stream and the event table, it constantly displays things like:
State: undefined - 384517633053032448.00 fps
State: undefined - -0.00 fps
State: undefined - -8869832211242951971478698291012378619241458565848170246425667418962815181209666205739307172533181672743934560622745185657100666694326303867436804561356013053097403994537978972121009596236753842786901878611985713076407240593768448.00 fps
State: undefined - 6.40 fps
State: undefined - 39577091234134084197709019239807702812141437927603943233878817567448921843734076176266549713914521258570787645881864000223840106330025511032690254696784511697104539203231446102003048677396740360046228908469805932783303801644215015061365052353768497872562935152532544683471330901397625820191462957376339968.00 fps
What did I miss?
Posted: Sun Jun 27, 2010 11:36 pm
by JungleGeorge
According to the following logs, the "Processing" rate is always less than the "Capturing" rate.
Jun 27 16:17:33 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 191000 - Processing at 27.78 fps]
Jun 27 16:17:54 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 207000 - Capturing at 29.41 fps]
Jun 27 16:18:09 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 192000 - Processing at 27.78 fps]
Jun 27 16:18:27 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 208000 - Capturing at 30.30 fps]
Jun 27 16:18:45 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 193000 - Processing at 27.78 fps]
Jun 27 16:19:00 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 209000 - Capturing at 30.30 fps]
Jun 27 16:19:21 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 194000 - Processing at 27.78 fps]
Jun 27 16:19:33 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 210000 - Capturing at 30.30 fps]
Jun 27 16:19:57 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 195000 - Processing at 27.78 fps]
Jun 27 16:20:00 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 195081 - Closing event 14, section end]
Jun 27 16:20:00 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 195081 - Opening new event 15, section start]
Jun 27 16:20:07 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 211000 - Capturing at 29.41 fps]
Jun 27 16:20:33 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 196000 - Processing at 27.78 fps]
Jun 27 16:20:40 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 212000 - Capturing at 30.30 fps]
Jun 27 16:21:08 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 197000 - Processing at 28.57 fps]
Jun 27 16:21:13 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 213000 - Capturing at 30.30 fps]
Jun 27 16:21:44 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 198000 - Processing at 27.78 fps]
Jun 27 16:21:46 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 214000 - Capturing at 30.30 fps]
Jun 27 16:22:20 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 215000 - Capturing at 29.41 fps]
Jun 27 16:22:20 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 199000 - Processing at 27.78 fps]
Jun 27 16:22:53 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 216000 - Capturing at 30.30 fps]
Jun 27 16:22:56 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 200000 - Processing at 27.78 fps]
Jun 27 16:23:27 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 217000 - Capturing at 29.41 fps]
Jun 27 16:23:32 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 201000 - Processing at 27.78 fps]
Jun 27 16:24:00 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 218000 - Capturing at 30.30 fps]
Jun 27 16:24:08 ubuntu04 zma_m2[1895]: INF [1_Axis_1031_W: 202000 - Processing at 27.78 fps]
Jun 27 16:24:34 ubuntu04 zmc_m2[1892]: INF [1_Axis_1031_W: 219000 - Capturing at 29.41 fps]
Does anything need to be done about this?
Posted: Mon Jun 28, 2010 2:13 pm
by mastayoda77
I have one of these cams as well. The Presets work for the 320x240 and you can tweak those for 480x360 and it works fine too. However, any time I try 640x480, whether I use presets or tweaked settings... I lose the connection to the camera.
If I were you I would try running it at the lower resolutions first and see if you have any luck there.
Posted: Fri Jul 09, 2010 2:52 pm
by coke
I've had 5 of those running on a machine (along with various others) at 640x480, and had no problems with any of them. And they can moo.
Posted: Fri Jul 09, 2010 5:56 pm
by JungleGeorge
mastayoda77 wrote:I have one of these cams as well. The Presets work for the 320x240 and you can tweak those for 480x360 and it works fine too. However, any time I try 640x480, whether I use presets or tweaked settings... I lose the connection to the camera.
Which 320x240 preset should I start with?
