I've got a Ubuntu 9.10 box running (built from an XBMC live CD) running on a Revo Aspire 3610. I'm running ZoneMinder v1.24.1
Linux Revo 2.6.31-16-generic #53-Ubuntu SMP Tue Dec 8 04:01:29 UTC 2009 i686 GNU/Linux
I cannot get the QuickCam 3000 for Business working under zoneminder
root@Revo:~# sudo zmu -d /dev/video0 -q -v
Error, failed to get channel 0 attributes: Invalid argument
07/02/10 19:04:05.094291 zmc_dvideo0[2419].INF-zm_debug.c/292 [New Debug Level = 6, New Debug Log = /tmp/zm_debug.log]
07/02/10 19:04:05.094807 zmc_dvideo0[2419].DB1-zm_monitor.cpp/1708 [Got 1 monitors]
07/02/10 19:04:05.094996 zmc_dvideo0[2419].DB2-zm_local_camera.cpp/287 [V4L2 support enabled, using V4L2 api]
07/02/10 19:04:05.098389 zmc_dvideo0[2419].DB1-zm_monitor.cpp/338 [monitor purpose=1]
07/02/10 19:04:05.098485 zmc_dvideo0[2419].DB1-zm_monitor.cpp/345 [mem.size=36865192]
07/02/10 19:04:05.147919 zmc_dvideo0[2419].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
07/02/10 19:04:05.184483 zmc_dvideo0[2419].DB1-zm_monitor.cpp/458 [Monitor Lounge has function 2]
07/02/10 19:04:05.184571 zmc_dvideo0[2419].DB1-zm_monitor.cpp/459 [Monitor Lounge LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
07/02/10 19:04:05.184615 zmc_dvideo0[2419].DB1-zm_monitor.cpp/460 [Monitor Lounge IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
07/02/10 19:04:05.185051 zmc_dvideo0[2419].DB1-zm_zone.cpp/889 [Got 1 zones for monitor Lounge]
07/02/10 19:04:05.185116 zmc_dvideo0[2419].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 639,0 639,479 0,479]
07/02/10 19:04:05.185160 zmc_dvideo0[2419].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 639,0 639,479 0,479']
07/02/10 19:04:05.185205 zmc_dvideo0[2419].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
07/02/10 19:04:05.185249 zmc_dvideo0[2419].DB3-zm_zone.cpp/796 [Got coordinate 639,0 from polygon string]
07/02/10 19:04:05.185291 zmc_dvideo0[2419].DB3-zm_zone.cpp/796 [Got coordinate 639,479 from polygon string]
07/02/10 19:04:05.185334 zmc_dvideo0[2419].DB3-zm_zone.cpp/796 [Got coordinate 0,479 from polygon string]
07/02/10 19:04:05.185386 zmc_dvideo0[2419].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
07/02/10 19:04:05.185434 zmc_dvideo0[2419].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:9216, MxAP:230400, FB:3x3, MnFP:9216, MxFP:230400, MnBS:6144, MxBS:0, MnB:1, MxB:0, OF: 0]
07/02/10 19:04:05.221957 zmc_dvideo0[2419].DB1-zm_monitor.cpp/1810 [Loaded monitor 1(Lounge), 1 zones]
07/02/10 19:04:05.222045 zmc_dvideo0[2419].INF-zmc.cpp/186 [Starting Capture]
07/02/10 19:04:05.222251 zmc_dvideo0[2419].DB3-zm_local_camera.cpp/350 [Opening video device /dev/video0]
07/02/10 19:04:05.222374 zmc_dvideo0[2419].DB2-zm_local_camera.cpp/356 [V4L2 support enabled, using V4L2 api]
07/02/10 19:04:05.222419 zmc_dvideo0[2419].DB3-zm_local_camera.cpp/361 [Checking video device capabilities]
07/02/10 19:04:05.222483 zmc_dvideo0[2419].DB3-zm_local_camera.cpp/371 [Setting up video format]
07/02/10 19:04:05.222563 zmc_dvideo0[2419].FAT-zm_local_camera.cpp/387 [Failed to set video format: Invalid argument]
07/02/10 19:04:05.222802 zmc_dvideo0[2419].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
root@Revo:~# ls -l /dev/video0
crw-rw---- 1 root video 81, 0 2010-07-02 18:49 /dev/video0
root@Revo:~# id www-data
uid=33(www-data) gid=33(www-data) groups=33(www-data),44(video)
root@Revo:~#
root@Revo:~# lsusb
Bus 001 Device 002: ID 046d:09a5 Logitech, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 045e:0284 Microsoft Corp. Xbox DVD Playback Kit
Bus 002 Device 002: ID 04f2:0402 Chicony Electronics Co., Ltd
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
kernel.shmmax = 167772160
kernel.shmall = 134217728
root@Revo:~# ipcs -l
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 163840
max total shared memory (kbytes) = 536870912
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 1718
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
If I use ffmpeg
ffmpeg -f video4linux2 -s 640x480 -r 30000/1001 -i /dev/video0 -y webcam.avi
EDIT
I've upgrade the lib4v drivers using the post here:
http://www.linwik.com/wiki/installing+t ... buntu+9.10
I can now run the zmu command
root@Revo:~# zmu -d /dev/video0 -q -v
Video Capabilities
Name: UVC Camera (046d:09a5)
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 640
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 640
Height: 480
Picture Attributes
Palette: 0 - Unknown
Colour Depth: 0
Brightness: 32896
Hue: 0
Colour :8224
Contrast: 8224
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
root@Revo:~#
07/02/10 20:50:25.118840 zmc_dvideo0[2530].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
07/02/10 20:50:25.118890 zmc_dvideo0[2530].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:9216, MxAP:230400, FB:3x3, MnFP:9216, MxFP:230400, MnBS:6144, MxBS:0, MnB:1, MxB:0, OF: 0]
07/02/10 20:50:25.155455 zmc_dvideo0[2530].DB1-zm_monitor.cpp/1810 [Loaded monitor 1(Lounge), 1 zones]
07/02/10 20:50:25.155557 zmc_dvideo0[2530].INF-zmc.cpp/186 [Starting Capture]
07/02/10 20:50:25.155755 zmc_dvideo0[2530].DB3-zm_local_camera.cpp/350 [Opening video device /dev/video0]
07/02/10 20:50:25.155872 zmc_dvideo0[2530].DB2-zm_local_camera.cpp/356 [V4L2 support enabled, using V4L2 api]
07/02/10 20:50:25.155916 zmc_dvideo0[2530].DB3-zm_local_camera.cpp/361 [Checking video device capabilities]
07/02/10 20:50:25.155979 zmc_dvideo0[2530].DB3-zm_local_camera.cpp/371 [Setting up video format]
07/02/10 20:50:25.156057 zmc_dvideo0[2530].FAT-zm_local_camera.cpp/387 [Failed to set video format: Invalid argument]
07/02/10 20:50:25.156281 zmc_dvideo0[2530].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
