Can only view 1 channel after adding a 2nd monitor
Geoff
Post by Geoff »
Hi all. I'm new to ZoneMinder and I'm having some issues migrating from Windows to Ubuntu. I'm running ZM 1.24.2-2build3 installed through Synaptic on Ubuntu 10.04. My first problem is that my capture card (a Q-See QSPDVR04 with a Techwell 6804 chipset) isn't well supported on Linux. I did find and install the tw68-v2 driver, and it seems like this works just fine. I can see my cameras perfectly with xawtv. I can also add a monitor with ZoneMinder. However, when I try to add more than 1 monitor at the same time (my card is a 4 channel card), the video for the 1st channel becomes the video for the 2nd channel. So I can only see a single channel on both monitors! The video also starts to flicker heavily. Any idea what could be causing this? Am I doomed to buying a new capture card/going back to Windows?
Here is the output of /var/log/messages:
Jul  5 21:21:23 ubuntu-server zmdc[4608]: INF [Server shutdown at 10/07/05 21:21:23]
Jul  5 21:21:23 ubuntu-server zmdc[4795]: INF [Server starting at 10/07/05 21:21:23]
Jul  5 21:21:26 ubuntu-server zmdc[4795]: INF ['zmc -d /dev/video0' starting at 10/07/05 21:21:26, pid = 4817]
Jul  5 21:21:26 ubuntu-server zmdc[4817]: INF ['zmc -d /dev/video0' started at 10/07/05 21:21:26]
Jul  5 21:21:26 ubuntu-server zmc_dvideo0[4817]: INF [Debug Level = 0, Debug Log = <none>]
Jul  5 21:21:26 ubuntu-server zmdc[4795]: INF ['zmc -d /dev/video0' already running at 10/07/05 21:21:26, pid = 4817]
Jul  5 21:21:26 ubuntu-server zmc_dvideo0[4817]: INF [Starting Capture]
Jul  5 21:21:26 ubuntu-server zmdc[4795]: INF ['zmfilter.pl' starting at 10/07/05 21:21:26, pid = 4820]
Jul  5 21:21:26 ubuntu-server zmdc[4820]: INF ['zmfilter.pl' started at 10/07/05 21:21:26]
Jul  5 21:21:26 ubuntu-server zmdc[4795]: INF ['zmaudit.pl -c' starting at 10/07/05 21:21:26, pid = 4822]
Jul  5 21:21:26 ubuntu-server zmdc[4822]: INF ['zmaudit.pl -c' started at 10/07/05 21:21:26]
Jul  5 21:21:26 ubuntu-server zmfilter[4820]: INF [Scanning for events]
Jul  5 21:21:26 ubuntu-server zmdc[4795]: INF ['zmwatch.pl' starting at 10/07/05 21:21:26, pid = 4824]
Jul  5 21:21:26 ubuntu-server zmdc[4824]: INF ['zmwatch.pl' started at 10/07/05 21:21:26]
Jul  5 21:21:27 ubuntu-server zmwatch[4824]: INF [Watchdog starting]
Jul  5 21:21:27 ubuntu-server zmwatch[4824]: INF [Watchdog pausing for 30 seconds]
Jul  5 21:21:29 ubuntu-server zms[4839]: INF [Debug Level = 0, Debug Log = <none>]
Jul  5 21:21:38 ubuntu-server zms[4839]: INF [Got signal 15 (Terminated), exiting]
Jul  5 21:21:39 ubuntu-server zms[4841]: INF [Debug Level = 0, Debug Log = <none>]
Jul  5 21:21:52 ubuntu-server zms[4841]: INF [Got signal 15 (Terminated), exiting]
Jul  5 21:23:11 ubuntu-server zms[4864]: INF [Debug Level = 0, Debug Log = <none>]
Jul  5 21:23:15 ubuntu-server zms[4864]: INF [Got signal 15 (Terminated), exiting]
Jul  5 21:23:48 ubuntu-server zmc_dvideo0[4817]: INF [Monitor-1: 1000 - Capturing at 7.04 fps]
Jul  5 21:23:48 ubuntu-server zmc_dvideo0[4817]: INF [Monitor-2: 1000 - Capturing at 7.04 fps]
Jul  5 21:24:36 ubuntu-server zms[4876]: INF [Debug Level = 0, Debug Log = <none>]
Jul  5 21:24:41 ubuntu-server zms[4876]: INF [Got signal 15 (Terminated), exiting]
Jul  5 21:24:42 ubuntu-server zms[4878]: INF [Debug Level = 0, Debug Log = <none>]
Jul  5 21:24:46 ubuntu-server zms[4878]: INF [Got signal 15 (Terminated), exiting]
Jul  5 21:24:47 ubuntu-server zms[4880]: INF [Debug Level = 0, Debug Log = <none>]
Jul  5 21:24:49 ubuntu-server zms[4880]: INF [Got signal 15 (Terminated), exiting]
Jul  5 21:25:52 ubuntu-server zmdc[4795]: INF ['zmc -d /dev/video0' stopping at 10/07/05 21:25:52]
Jul  5 21:25:52 ubuntu-server zmc_dvideo0[4817]: INF [Got signal 15 (Terminated), exiting]
Jul  5 21:25:52 ubuntu-server zmdc[4795]: INF ['zmc -d /dev/video0' exited normally]
Jul  5 21:25:52 ubuntu-server zmdc[4795]: INF ['zmc -d /dev/video0' starting at 10/07/05 21:25:52, pid = 4909]
Jul  5 21:25:52 ubuntu-server zmdc[4909]: INF ['zmc -d /dev/video0' started at 10/07/05 21:25:52]
Jul  5 21:25:52 ubuntu-server zmc_dvideo0[4909]: INF [Debug Level = 0, Debug Log = <none>]
Jul  5 21:25:52 ubuntu-server zmdc[4795]: WAR [Can't find process with command of 'zma -m 17']
Jul  5 21:25:52 ubuntu-server zmc_dvideo0[4909]: INF [Starting Capture]
Jul  5 21:25:56 ubuntu-server zms[4926]: INF [Debug Level = 0, Debug Log = <none>]
Jul  5 21:26:00 ubuntu-server zms[4926]: INF [Got signal 15 (Terminated), exiting]
Jul  5 21:27:25 ubuntu-server zmc_dvideo0[4909]: WAR [Capture failure, possible signal loss?: Input/output error]
Jul  5 21:27:25 ubuntu-server kernel: [ 5282.130007] tw6804[0]/0: [ffff88011773f800/3] timeout - dma=0xc6e0e000
Jul  5 21:27:25 ubuntu-server kernel: [ 5282.130011] tw6804[0]/0: [ffff88011773e200/0] timeout - dma=0xcfa16000
Jul  5 21:27:25 ubuntu-server kernel: [ 5282.130014] tw6804[0]/0: [ffff88011773f200/1] timeout - dma=0xcfa3a000
Jul  5 21:27:25 ubuntu-server kernel: [ 5282.130016] tw6804[0]/0: [ffff88011773e800/2] timeout - dma=0xc6f54000
Jul  5 21:27:25 ubuntu-server zmdc[4795]: INF [Starting pending process, zmc -d /dev/video0]
Jul  5 21:27:25 ubuntu-server zmdc[4795]: INF ['zmc -d /dev/video0' starting at 10/07/05 21:27:25, pid = 4961]
Jul  5 21:27:25 ubuntu-server zmdc[4961]: INF ['zmc -d /dev/video0' started at 10/07/05 21:27:25]
Jul  5 21:27:25 ubuntu-server zmc_dvideo0[4961]: INF [Debug Level = 0, Debug Log = <none>]
Jul  5 21:27:25 ubuntu-server zmc_dvideo0[4961]: INF [Starting Capture]
Regards,
Geoff Akerlund
bb99
Post by bb99 »
Try increasing CAPTURES_PER_FRAME to 2 or 3. I believe this is a one chip card and this setting change is well documented in the forums to work on other single chip cards. You will take a fps hit though.
