Page 1 of 1
Unable to update
Posted: Fri Jul 09, 2010 10:45 pm
by Fitch
In zmupdate.log I have a lot of lines similar to this one:
09/07/10 23:20:05.675020 zmupdate[4110].INF [Checking for updates]
09/07/10 23:20:05.677326 zmupdate[4110].ERR [Error check failed: '500 Can't connect to www.zoneminder.com:80 (Bad hostname 'www.zoneminder.com')']
What does it mean and how can I rectify it?
Posted: Sat Jul 10, 2010 3:27 am
by bb99
Untick CHECK_FOR_UPDATES in options. Your installation is having DNS issues or not able to connect externally from your network. This is actually a good sign security wise if you have ZM setup to be intranet only.
Posted: Sat Jul 10, 2010 1:04 pm
by Fitch
O.K. then!
will leave things well alone (except for the unticking bit)
Thanks.
