zoneminder ffmpeg progressive degrading quality
When I first start up zoneminder I get a nice crystal clear image. After a period of 15 minutes I get boxy rainbows all over the jpeg. Worse yet It detects these boxy rainbows as motion. To make sure it wasn't the driver I did a cat /dev/cxm0 >> deleteme.mpg and was able to play a nice crisp picture. I am thinking I need to pass some codecs or arguments to ffmpeg.
Camera:
Lorex CVC6994CL
High Resolution Color Security Camera
http://lorexstore.lorextechnology.com/p ... ECS_R4.pdf
tuner card
composite input
hauppauge WinTV-PVR-150
My picture above is just the worst of how it looks. It starts out with little boxes and gradually moves up to that.
Although someone noted on this forum that this is nothing to worry about
Jul 11 13:17:53 cam kernel: cxm0: encoder dma not enough buffer space free
I kind of wonder if it could be the source of my degrading video quality. When I restart zoneminder everything gets better for about 2 minuites.
Lorex CVC6994CL
tuner card
composite input
after running 1/2 hour.
I've already checked the log files. and posted what I got out of them. I wouldn't be here if that wasn't something I already tried.
I have discovered that occasionally executing ffmpeg from shell seems to reset things back to normal. The picture should normally be a very crystal clear/sharp image.
I'm also open to purchasing a different tuner card.
I don't believe this applies in your situation as it seems to be ffmpeg related, but I was having a similar issue with a cheap card I purchased off ebay (by similar I mean the displayed picture would show odd colours). The solution was to reduce the fps the capture card recorded at, as the card was overheating at the full 25fps (PAL).
i had problems setting a fixed bitrate for ffmpeg while creating a video from the events. basically the same happened here, the quality degraded towards the end of the file - my solution was to 'hardwire' my desired bitrate as you see here:
http://www.zoneminder.com/forums/viewtopic.php?t=15202
if you look around you'll find the code that controls the streaming in another program file
my guess is that certain ffmpeg versions are a little bit buggy and need more attention than others, and don't calculate the bitrate vs framerate vs framesize correctly
pls send emails to 'myusername at google dot com'
Same problem
I'm having the same problem with an ACTi IP camera. When I set the source type to remote, I get decent stills with lots of movement artifacts. When I set source to ffmpeg, the live feed is crystal clear for about 30 seconds then starts to "melt".
I've been trying to find a solution for the past three weeks and so far have nothing.
I have the same issue with Edimax IC-9000 (aka StarVedia IC-602) camera's. I have these connected to Zoneminder using 'ffmpeg' using the url format:
rtsp://<user>:<password>@<ip>/<camera>.mp2
That produces 640x480 images quite nicely. I was running Zoneminder on a netbook and noticed that when limiting the framerate using 'Max FPS' in the monitor definition, I got this melting/bleeding effect as described. Without this limiting, the poor N270 Atom CPU was stretched to its limit and overall experience was suffering.
Now I'm running Zoneminder on a dedicated Atom D510 based server and I've left that Max FPS blank. Now everything remains crisp!
The negative bit about this is that the recording now happens at 10 fps, 2 cameras, 640x480... My HD is filling up quite quickly.
Re: zoneminder ffmpeg progressive degrading quality
Hi
I also have a Ic9000 edimax cam. I found this explanation on the internet:
THX Neo
How could/should I configure zm to work with the cam? All tests witch I made didn't work for me.Appendix F. Third party and embedded web page
integration
For third party and embedded web page integration, IP Cam support the standard RTSP protocol and video codecs needed by most generally used video play software, including Apple QuickTime and VideoLAN. The supported media protocols including TCP and UDP. IP Cam will automatically use TCP or UDP media stream depends on the connection request. The video codec supported is MPEG4.
The access methods are the followings : rtsp://CAM-IP/CAMID.PW.mp2 for MPEG4 video + MPEG2 audio
rtsp://CAM-IP/CAMID.PW for MPEG4 video + AMR-NB audio
Where ip_cam_address is the IP address of the IP camera. CAM_ID is the unique Camera ID of the specific IP camera. Password is the video play password of the specific IP camera(detailed in section 3.6). Users can modify the password of the IP camera to prevent others to see the video.
For embedded web page integration, add the following codes into the proper position of the desired web page :
<object classid="clsid:5C519EC4-2BAE-44CE-B7F5-AD0CCD4BEFBD" id="mpeg4ax" codebase=">>>>Link removed"<<<<#Version=0,0,0,0" width="320" height="240">
<param name="Src" value="rtsp://CAM-IP/CAMID.PW.mp2"> </object>
THX Neo
