[SOLVED]: PHP Errors
Posted: Mon Jul 19, 2010 2:29 pm
ZM 1.24.2 on Ubuntu 10.04
Copy of Apache2 log below;
[Mon Jul 19 15:18:17 2010] [error] [client 127.0.0.1] PHP Warning: Unknown: open(/var/lib/php5/sess_8j32dks3cmvfso0vchntj24gt7, O_RDWR) failed: Permission denied (13) in Unknown on line 0, referer: http://localhost/index.php?username=xxx ... ew=montage
[Mon Jul 19 15:18:17 2010] [error] [client 127.0.0.1] PHP Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php5) in Unknown on line 0, referer: http://localhost/index.php?username=xxx ... ew=montage
What attributes should /var/lib/php5 be?
Is this a fault with ZM?
Currently /var/lib/php5 is
drwx-wx-wt 2 root root 4096 2010-07-19 15:18 php5
Is this correct??
Is this correct??
