Dears,
I couldn't get an IP Camera work in monitor mode. Could anyone help me? This camera compression type seems OK, which is M-JPEG, and you don't need an ActiveX to open its HTTP live streams, I can open the IP camera in firefox browser.
I bought the IP Camera from China. In English it's called Unifly 101. You won't find the camera if you are using the word "Unifly 101". You have to type in Chinese name "环宇飞扬 101" either in www.google.com or www.baidu.com
Here is the link of the product
http://item.taobao.com/item.htm?id=5420172336
Here is the specification (Google Translate):
Sensor: High Resolution 1 / 4 "CMOS image sensor
Lens: 5 high-resolution infrared lens glass
Infrared light up: Support 6 infrared LED, illumination automatically open
Image Resolution: (640x480) / (320x240) / (160x120) Optional
Image Compression: M-JPEG
Image frame rate: the case of bandwidth to allow video image transmission can achieve 30 frames / sec
Sensing and control: support for an external volume sensor switch 2, a relay switch output
Alarm Detection: support alarm can be triggered
Video transmission: network camera supports up to 12 simultaneous users to access
User access: Built-in Web Server, allow remote users to directly access the Web browser, network camera
Certification / Encryption: Users with password access to the network camera, 3-level access permissions to ensure users safety
Network Protocols: TCP / IP, UDP, IMCP, SMTP, HTTP, FTP, DNS, DDNS DHCP, PPPoE
Network connection :10-100Base-T Ethernet interface, RJ45 connector
Supporting software: distribution <IPCam> and <16> Software
Software upgrade: Support FTP software upgrade
Power supply: DC 5V/1A external power supply
My latest log when I tried to view the camera:
Jul 25 22:31:00 n00bita-desktop zmdc[6525]: INF [Starting pending process, zmc -m 1]
Jul 25 22:31:00 n00bita-desktop zmdc[6525]: INF ['zmc -m 1' starting at 10/07/25 22:31:00, pid = 9440]
Jul 25 22:31:00 n00bita-desktop zmdc[9440]: INF ['zmc -m 1' started at 10/07/25 22:31:00]
Jul 25 22:31:00 n00bita-desktop zmc_m1[9440]: INF [Debug Level = 0, Debug Log = <none>]
Jul 25 22:31:00 n00bita-desktop zmc_m1[9440]: INF [Starting Capture]
Jul 25 22:31:06 n00bita-desktop zms[9460]: INF [Debug Level = 0, Debug Log = <none>]
Jul 25 22:31:06 n00bita-desktop zms[9460]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Jul 25 22:31:20 n00bita-desktop zmdc[6525]: INF [Starting pending process, zmc -m 1]
Jul 25 22:31:20 n00bita-desktop zmdc[6525]: INF ['zmc -m 1' starting at 10/07/25 22:31:20, pid = 9470]
Jul 25 22:31:20 n00bita-desktop zmdc[9470]: INF ['zmc -m 1' started at 10/07/25 22:31:20]
Jul 25 22:31:20 n00bita-desktop zmc_m1[9470]: INF [Debug Level = 0, Debug Log = <none>]
Jul 25 22:31:20 n00bita-desktop zmc_m1[9470]: INF [Starting Capture]
Jul 25 22:31:21 n00bita-desktop pulseaudio[3979]: ratelimit.c: 1 events suppressed
Jul 25 22:31:44 n00bita-desktop zmu[9472]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Jul 25 22:31:45 n00bita-desktop zmu[9474]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
