I'm in the market for the following :
1 x 8ch 240fps capture card with a supported chipset.
or
2 x 4ch 120fps capture cards with a supported chipset
and 8 compatible cameras.
I'm a little confused as to what TYPE of cameras I should be looking for. Basically; they need to be compatible with the 4/8ch capture card, and preferably wired. But there are CCD cameras, CMOS cameras, cameras that can connect directly to a TV, etc.
What type of camera should I be searching for ? Is there some kind of collective term for the type of camera I need ?
Thanks in advance
Justin
Capture card & camera advice
Until someone more knowledgeable than me comes along have a look here, might get you on the right track
Zoneminder supported page
http://store.bluecherry.net/category_s/95.htm
Also check the Wiki on this site
Good luck ;o)
Good luck ;o)
