Kodicom 4400r, only able to see 2 channels
galaxyranger
Post by galaxyranger »
Howdy,
I'm using ZM 1.24.1 under Ubuntu 9.10. The setup has 14 cameras connected and all were working previously under Windows, with this same card, before a motherboard failure. Seeing my chance I've made the new machine a linux box and implemented ZM.
I got the modprobe stuff out of the way and can now all the channels are listed in tvtime and xawtv, but I'm only able to see feeds from channel 6 and 14. I'm going back tomorrow armed with everything I can find about setting up the card, as well as tracking down the security guy so I can actually verify the cameras are still up, but I wanted to check here and see if any of you good peoples have seen a similar issue or had any thoughts.
lspci shows the video interfaces as bt878 rev 11, if that's of any importance.
Thanks!
