Video Stream Very Slow
erik258
Post by erik258 »
I'm running zoneminder 1.24 with a few IP cameras. The IP cameras (One foscam, one other) are working well in streaming mode. However, zoneminder itself is having a lot of difficulty serving montage or single monitor viewing windows. They lag significantly, by some tens of seconds; however, the timestamp on the image is that of the current time.
To be clear, I offer this example. I set up a camera and walk in front of it. Then I click on the name of the camera in zoneminder and bring up the monitor viewer. It plays a few frames - with the current time - but won't stream them. If I press 'refresh' over and over again, I slowly step through the frames and will eventually get to the point where I walked through in front of the camera, but it will have a timestamp from when it was shown rather than when the image was captured.
I first thought this problem was caused by too high a framerate, but dropping it down to even 4 fps didn't really help. I haven't tried decreasing the resolution, because I'd like to capture at 640x480. The system is slowish - it's an intel atom n270 at 1.6 ghz - but it's only at 60% load or so, so it seems like it should be working better.
I've been meaning to test it on a faster box, but haven't yet.
I'm hoping the zoneminder community has thoughts about how I might be able to rectify this. Optimally, I'd be capturing ~15 frames per second at 640x480 from 4 cameras at once. Does it seem like this should be possible? Can anyone offer up a suggestion as to how I could get the streaming to perform adequately?
ilios
Post by ilios »
up
F5 is our mantra
wollo
Post by wollo »
I've just set up two of the foscams. Make sure that in zone minder monitor properties page you set the framerate through the adress window not the frame rate options themselves, leave those empty or you get the problem with lag.
On another note does your foscam crash often when using zoneminder?
