debian testing (2.6.30-1-686)
generic bt878 (8chips) card
4X CCD cams
when I configure some types of realtime visualizations (like via web montage, zmviewer, xlib_shm) there is the same problem, after some time 1/2 hours viewer crash...
when I check dmesg find that my bt878 card is recognized by system as saa7134!
however zm work in modect without problems.
my dmesg higlights:
[ 5.086494] saa7130/34: v4l2 driver version 0.2.15 loaded
[ 5.086543] saa7134 0000:04:08.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 5.086550] saa7130[0]: found at 0000:04:08.0, rev: 1, irq: 16, latency: 64,
mmio: 0xfebffc00
[ 5.086557] saa7134: <rant>
[ 5.086558] saa7134: Congratulations! Your TV card vendor saved a few
[ 5.086559] saa7134: cents for a eeprom, thus your pci board has no
[ 5.086560] saa7134: subsystem ID and I can't identify it automatically
[ 5.086561] saa7134: </rant>
[ 5.086561] saa7134: I feel better now. Ok, here are the good news:
[ 5.086562] saa7134: You can use the card=<nr> insmod option to specify
[ 5.086563] saa7134: which board do you have. The list:
[...] long list
[ 5.812696] saa7130[7]: subsystem: 1131:0000, board: UNKNOWN/GENERIC [card=0,autodetected]
[ 5.812723] saa7130[7]: board init: gpio is 10000
[ 5.812728] IRQ 19/saa7130[7]: IRQF_DISABLED is not guaranteed on shared IRQs
[ 5.916079] saa7130[7]: Huh, no eeprom present (err=-5)?
[ 5.916159] saa7130[7]: registered device video7 [v4l2]
[ 5.916197] saa7130[7]: registered device vbi7
I think that the correct module is bttv with 77 card type...
Thanks for help!
