Hi all,
I'm trying an Axis P1344 which has support for H.264 and MJPEG. I'm unable to get video to come up based on info on the 2xx series. (yes, different camera, differnet tech, I undertstand..)
Has anyone tried this or have any hints.
Parameter Value
Remote Host Name remote:remote@192.168.15.38
Remote Host Port 554
Remote Host Path /mjpg/video.cgi
Remote Image Colours 24 Bit
Capture Width (pixels) 320
Capture Height (pixels) 240
Orientation Normal
Comes up all Green on the ZM interface, but no image, Also can get image via
http://remote:remote@192.168.15.38/axis ... /video.cgi
Any advise or guidance would be much appreciated.
Axis P1344
Hi ,
i have your same problem with P1344 ,
my zm run on Centos 5.5 with ffmpeg from rpmforge ,
i connect like " rtps://ip-add/axis-media/media.amp "
or /media.3gp
in both case i got a black screen: i mean i see cambozola load then the black screen.
I tryed almost all possible resolution and streaming ( h264 - mjpeg ) the size of the black screen change but still no image,
and...this system works lovely with 4 axis cam's , one is the powerfull Q1755 ( 1080p resulution )
I have also a test virtual machine ( vmware ) with ffmpeg build from source : same problem
Any help would be much appreciated
THX
or /media.3gp
THX
Re: Axis P1344
HI
Please tell me the configuration for AXIS Q1755. I got one to be configured on ZM 1.24.4
Thanks.
Prasad
Thanks.
Prasad
