Export Events problem - creating empty files...
v1.24.2, Debian testing.
The data hard drive is dying and I would like to export the archived events before I install a replacement. Either in jpg or video, don't mind.
I select all the archive pics from the filter view, the thumbnails appear and I click 'Export' at the bottom.
I then tick all the boxes in the "Export Options" box and choose Tar as format. Click Export.
I get "Export Succeeded - Download", click download and receive a .tgz file.
Unfortunately, it's empty. Filesize of 54 bytes, just the tgz wrapper with no files inside it.
I've ensured /var/cache/zoneminder/temp is world-writeable, and it's creating two files in there ok;
cradle:/var/cache/zoneminder/temp# ls -l
total 4
-rw-r--r-- 1 www-data www-data 45 2010-08-19 12:12 zmExport.tar.gz
-rw-r--r-- 1 www-data www-data 0 2010-08-19 12:12 zmFileList.txt
But as you can see, zmFileList.txt is empty, suggesting something went wrong before tar and gzip got to work.
Can't find anything useful in the logs.
What have I missed?
(Tested same process on another server running 1.22.3 and that works fine)
total 4
What have I missed?
Ahh, found this is apache's error_log
[Thu Aug 19 12:24:51 2010] [error] [client 10.0.0.242] PHP Warning: array_merge(): Argument #1 is not an array in / usr/share/zoneminder/skins/classic/includes/export_functions.php on line 255, referer: http://10.0.3.10/zm/index.php ?view=export&eids[]=226962&eids[]=226959&eids[]=226955&eids[]=226952&eids[]=224012&eids[]=224010&eids[]=224003&eids[ ]=223999&eids[]=223993&eids[]=220351&eids[]=220341&eids[]=220230&eids[]=220226&eids[]=220220&eids[]=212598&eids[]=21 2572&eids[]=212535&eids[]=212453&eids[]=211699&eids[]=211698&eids[]=211695&eids[]=211696&eids[]=211681&eids[]=211589 &eids[]=211514&eids[]=203878&eids[]=60110&eids[]=60109&eids[]=60103&eids[]=60100&eids[]=60092&eids[]=60088&eids[]=60 083&eids[]=60077&eids[]=60071&eids[]=60061&eids[]=60058&eids[]=60049&eids[]=60052&eids[]=60044&eids[]=60041&eids[]=6 0035&eids[]=43909&eids[]=41838&eids[]=41832&eids[]=34998&eids[]=34730&eids[]=34121&eids[]=30652&eids[]=30645&eids[]= 30634&eids[]=30629&exportFile=undefined&generated=0
The problem is that the behavior of array_merge changed in PHP5. Zoneminder's export function breaks.
The line in question is in /usr/share/zoneminder/skins/classic/includes/export_functions.php
$exportFileList = array_merge( $exportFileList, exportFileList( $eid ), $exportDetail, $exportFrames, $exportImages, $exportVideo, $exportMisc );
Various howtos suggest adding (array) before the variables. I've tried that and it fails for but not being a php coder I'm a bit hit and miss here.
Anyone fancy fixing this line to adhere to the php5 standards?
Single event export was broken too - in a different way. I've fixed that by some quick hackery;
Line 161 of /usr/share/zoneminder/skins/classic/includes/export_functions.php
Because /data/ is my zoneminder root path and for some reason this wasn't being prepended by the export function so it couldn't find the files.
After error_log entries of
PHP Warning: opendir(events/6/60109): failed to open dir: No such file or directory in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 163, referer:
Multiple exports are still broken for me as above, though.
$eventPath = getEventPath( $event );
to
$eventPath = '/data/' . getEventPath( $event );
Export Failed from Multiple Events Fixed
Hi, I had the same problem and have it fixed. Just modify line 255 from the file zm/skins/classic/includes/export_functions.php from:
to:
$exportFileList = array_merge( $exportFileList, exportFileList( $eid , $exportDetail, $exportFrames, $exportImages, $exportVideo, $exportMisc ));
Good luck!
to:
Good luck!
Re: Export Events problem - creating empty files...
I'm now having this same problem when exporting a single event. The tar file downloads fine but it is empty.
Here is my apache2 error log. Had to remove some paths because the forum thought they were links.
I am checking all of the boxes and selecting tar format in the export window.
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Warning: Missing argument 2 for exportFileList(), called in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 255 and defined in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 153, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Warning: Missing argument 3 for exportFileList(), called in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 255 and defined in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 153, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Warning: Missing argument 4 for exportFileList(), called in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 255 and defined in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 153, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Warning: Missing argument 5 for exportFileList(), called in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 255 and defined in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 153, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Warning: Missing argument 6 for exportFileList(), called in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 255 and defined in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 153, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Notice: Undefined variable: exportDetail in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 178, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Notice: Undefined variable: exportFrames in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 189, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Notice: Undefined variable: exportImages in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 200, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Notice: Undefined variable: exportVideo in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 216, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Notice: Undefined variable: exportMisc in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 232, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Warning: array_merge(): Argument #3 is not an array in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 255, referer: index.php?view=export&eids[]=24
[Tue Jun 07 15:50:08 2011] [error] [client 192.168.57.8] PHP Warning: Invalid argument supplied for foreach() in /usr/share/zoneminder/skins/classic/includes/export_functions.php on line 269, referer: index.php?view=export&eids[]=24
Re: Export Failed from Multiple Events Fixed
Is this fixed in ZoneMinder 1.24.4?amppjunior wrote:Hi, I had the same problem and have it fixed. Just modify line 255 from the file zm/skins/classic/includes/export_functions.php from:
to:
Good luck!
mastertheknife
Kfir Itzhak.
