In the file ajax/stream.php i changed the line 11
if ( !($socket = @socket_create( AF_UNIX, SOCK_DGRAM, 0 )) )
if ( !($socket = @socket_create( AF_UNIX, SOCK_DGRAM, SOL_UDP )) )
BUT... break the status FPS and State. Also de progress bar. So, this is not a fix, but may be a starting point to solve this hard bug about sockets. Maybe who knows what to do, then can fix this problem.
Why with this change the sockets are fine, and apache no hangs and run all like a charm? For investigate.
