New camera and detection method
Posted: Fri Aug 27, 2010 9:25 am
I'm a new user of zoneminder (really great script !) everything works fine except two things:
1. I've a new webcam (D-Link DCS-2121) which should work with RTSP protocol and a resolution of 640x480 to 1024x768. But I can't find a way to make it working fine with RTSP, after a search on this forum I found an alternative, use HTTP protocol but it's not so good as RTSP for example the resolution seems to be fixed to 512x384.
2. I use "Mocord" for all cam...the detection works fine, at least I can see some pictures with red lines around some people. But I assume that with "Mocord" it should only rec pictures when an action is detected but actually it rec everything and every ten minutes a new event is created. For example during the night, it rec everything but on some events I've 0 in images alarm, score total, ... so for me it should not be recorded.
