Trendnet TV-IP121W compatibe?
joe.c.johnson
Post by joe.c.johnson »
just want to ask if Trendnet TV-IP121W is compatible with ZM and what is the image path.thanks.
aperry
Re: Trendnet TV-IP121W compatibe?
Post by aperry »
I am considering purchasing one of these. Any luck configuring it with ZM?
Thanks,
Aaron
TheShniz
Post by TheShniz »
I too am looking for the correct path/settings... none of the other TrendNet appear to apply to this model; anybody know?
I appreciate it!
- J
rewrite
Post by rewrite »
just got this camera yesterday and found the path to mjpg is htt p://ip_address:port/cgi/mjpg/mjpg.cgi
it requires you to log in first so when setting up the remote camera in zoneminder,
make sure the Remote Host Name is in this format: username:password@ip_address
Remote Host Path: /cgi/mjpg/mjpg.cgi
it works for me without any issue.
MakOwner
Post by MakOwner »
This may be a little dated, as the TrendNet TV-IP121WN is now discontinued, but I found one at a discount at the local Fry's.
I just installed Zoneminder on a headless Ubuntu 12.04 server for the first time and within a few minutes had it working (at least for monitor) over a wired interface.
It has wirless capability, but I'm not using it.
I have attached screen shots of the settings I used. Well, I can't seem to figure out how to do two screen shots in s single post, so you can see the source tab.
Source tab
Source tab
