I'm now under ubuntu 10.04 (lucid lynx) and I try to install a new config on a netbook with Zoneminder 1.24.
Install without problem but its impossible to see any stream with these 3 : internet UVC Webcam, external analogic cam (wich worked fine in my old config) and external creative webcam.
Lines monitors are always red and when I open I've blank screens.
I tried to use remote option with UVC cam and mjpg_streamer as indicate on wiki : no result.
I also tried zmfix.
All these cams are working with xawtv and other viewers.
Thanks very much for your help, here is the result of commands :
lepapoubis@lepapoubis-laptop:~$ xawtv -hwscan
This is xawtv-3.95.dfsg.1, running on Linux/i686 (2.6.32-21-generic)
looking for available devices
port 71-86
type : Xvideo, image scaler
name : Intel(R) Textured Video
port 87-87
name : Intel(R) Video Overlay
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
name : USB2.0 UVC VGA WebCam
flags: capture
lepapoubis@lepapoubis-laptop:~$ sudo zmu -d /dev/video0 -q -v -U lepapoubis -P pass
[sudo] password for lepapoubis:
Error, failed to query crop /dev/video0: Invalid argument
lepapoubis@lepapoubis-laptop:~$ v4l-info
### v4l2 device info [/dev/video0] ###
general info
VIDIOC_QUERYCAP
driver : "uvcvideo"
card : "USB2.0 UVC VGA WebCam"
bus_info : "usb-0000:00:1d.7-6"
version : 0.1.0
capabilities : 0x4000001 [VIDEO_CAPTURE,STREAMING]
standards
inputs
VIDIOC_ENUMINPUT(0)
index : 0
type : CAMERA
audioset : 0
tuner : 0
std : 0x0 []
status : 0x0 []
video capture
VIDIOC_ENUM_FMT(0,VIDEO_CAPTURE)
index : 0
type : VIDEO_CAPTURE
flags : 0
description : "YUV 4:2:2 (YUYV)"
pixelformat : 0x56595559 [YUYV]
VIDIOC_G_FMT(VIDEO_CAPTURE)
fmt.pix.width : 640
fmt.pix.height : 480
fmt.pix.pixelformat : 0x56595559 [YUYV]
fmt.pix.field : NONE
fmt.pix.bytesperline : 1280
fmt.pix.sizeimage : 614400
fmt.pix.colorspace : SRGB
fmt.pix.priv : 0
controls
VIDIOC_QUERYCTRL(BASE+0)
type : INTEGER
minimum : 0
maximum : 255
step : 1
default_value : 128
flags : 0
VIDIOC_QUERYCTRL(BASE+1)
type : INTEGER
minimum : 0
maximum : 255
step : 1
default_value : 128
flags : 0
VIDIOC_QUERYCTRL(BASE+2)
type : INTEGER
minimum : 0
maximum : 127
step : 1
default_value : 64
flags : 0
VIDIOC_QUERYCTRL(BASE+3)
type : INTEGER
minimum : -180
maximum : 180
step : 1
default_value : 0
flags : 0
### video4linux device info [/dev/video0] ###
general info
VIDIOCGCAP
name : "USB2.0 UVC VGA WebCam"
type : 0x1 [CAPTURE]
channels : 1
audios : 0
maxwidth : 640
maxheight : 480
minwidth : 48
minheight : 32
channels
VIDIOCGCHAN(0)
channel : 0
tuners : 0
flags : 0x0 []
type : CAMERA
norm : 0
tuner
ioctl VIDIOCGTUNER: Invalid argument
audio
ioctl VIDIOCGAUDIO: Invalid argument
VIDIOCGPICT
brightness : 32896
hue : 32768
colour : 33026
contrast : 32896
whiteness : 10813
depth : 16
palette : YUYV
buffer
ioctl VIDIOCGFBUF: Invalid argument
window
VIDIOCGWIN
x : 0
y : 0
width : 640
height : 480
chromakey : 0
flags : 0
