BT878 card not loading
Posted: Thu Sep 09, 2010 10:47 am
This card was working correctly but then stopped. I would appreciate any help.
I'm running Zoneminder v1.24.2 on Ubuntu 10.04.1
Below is the output of dmesg | grep bttv
[ 11.503559] bttv: driver version 0.9.18 loaded
[ 11.503562] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 11.504215] bttv: Bt8xx card found (0).
[ 11.504226] bttv 0000:01:08.0: Refused to change power state, currently in D3
[ 11.504456] bttv 0000:01:08.0: PCI INT A -> Link[APC1] -> GSI 16 (level, low) -> IRQ 16
[ 11.504465] bttv0: Bt878 (rev 255) at 0000:01:08.0, irq: 16, latency: 255, mmio: 0xe2000000
[ 11.504751] bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 11.504754] IRQ 16/bttv0: IRQF_DISABLED is not guaranteed on shared IRQs
[ 11.504787] bttv0: gpio: en=ffffffff, out=ffffffff in=00000000 [init]
[ 11.504961] bttv0: tuner absent
[ 11.504963] bttv0: the autoload option is obsolete.
[ 11.504965] bttv0: use option msp3400, tda7432 or tvaudio to
[ 11.504967] bttv0: override which audio module should be used.
[ 11.505099] bttv0: registered device video0
[ 11.505200] bttv0: registered device vbi0
[ 11.505215] bttv0: PLL: 28636363 => 35468950 ......Console: switching to colour frame buffer device 80x30
[ 11.676817] bttv0: PLL: 28636363 => 35468950 .
[ 11.677602] bttv0: PLL: 28636363 => 35468950 .............
[ 11.837064] bttv0: PLL: 28636363 => 35468950 .failed
[ 11.837078] bttv0: PLL: 28636363 => 35468950 ...........
[ 20.222789] bttv0: PLL: 28636363 => 35468950 .
[ 20.230599] bttv0: PLL: 28636363 => 35468950 ...................failed
[ 20.384040] bttv0: PLL: 28636363 => 35468950 .failed
[ 20.389042] bttv0: PLL: 28636363 => 35468950 ...................failed
[ 102.931945] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 103.089091] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 103.249906] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 103.409020] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 104.085026] bttv0: timeout: drop=0 irq=0/0, risc=ffffffff, bits: FMTCHG VSYNC HSYNC OFLOW HLOCK VPRES 6 7 I2CDONE GPINT 10 RISCI FBUS FTRGT FDSR PPERR RIPERR PABORT OCERR SCERR
[ 104.163701] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 104.320043] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 104.480177] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 104.640031] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 105.328028] bttv0: timeout: drop=0 irq=0/0, risc=ffffffff, bits: FMTCHG VSYNC HSYNC OFLOW HLOCK VPRES 6 7 I2CDONE GPINT 10 RISCI FBUS FTRGT FDSR PPERR RIPERR PABORT OCERR SCERR
[ 110.114324] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 110.272040] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 110.432230] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 110.592055] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 111.280023] bttv0: timeout: drop=0 irq=0/0, risc=ffffffff, bits: FMTCHG VSYNC HSYNC OFLOW HLOCK VPRES 6 7 I2CDONE GPINT 10 RISCI FBUS FTRGT FDSR PPERR RIPERR PABORT OCERR SCERR
[ 121.076583] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 121.237043] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 121.396188] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 121.556339] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 122.248023] bttv0: timeout: drop=0 irq=0/0, risc=ffffffff, bits: FMTCHG VSYNC HSYNC OFLOW HLOCK VPRES 6 7 I2CDONE GPINT 10 RISCI FBUS FTRGT FDSR PPERR RIPERR PABORT OCERR SCERR
[ 142.102630] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 142.260039] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 142.420186] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 142.580036] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 143.268029] bttv0: timeout: drop=0 irq=0/0, risc=ffffffff, bits: FMTCHG VSYNC HSYNC OFLOW HLOCK VPRES 6 7 I2CDONE GPINT 10 RISCI FBUS FTRGT FDSR PPERR RIPERR PABORT OCERR SCERR
[ 183.152446] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 183.308038] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 183.468182] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 183.628037] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 184.317038] bttv0: timeout: drop=0 irq=0/0, risc=ffffffff, bits: FMTCHG VSYNC HSYNC OFLOW HLOCK VPRES 6 7 I2CDONE GPINT 10 RISCI FBUS FTRGT FDSR PPERR RIPERR PABORT OCERR SCERR
[ 264.068421] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 264.229092] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 264.388189] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 264.548029] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 265.240027] bttv0: timeout: drop=0 irq=0/0, risc=ffffffff, bits: FMTCHG VSYNC HSYNC OFLOW HLOCK VPRES 6 7 I2CDONE GPINT 10 RISCI FBUS FTRGT FDSR PPERR RIPERR PABORT OCERR SCERR
[ 425.116902] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 425.272038] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 425.432205] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 425.592029] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 426.280026] bttv0: timeout: drop=0 irq=0/0, risc=ffffffff, bits: FMTCHG VSYNC HSYNC OFLOW HLOCK VPRES 6 7 I2CDONE GPINT 10 RISCI FBUS FTRGT FDSR PPERR RIPERR PABORT OCERR SCERR
[ 746.065907] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 746.228025] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 746.388132] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 746.544038] bttv0: PLL: 28636363 => 35468950 ..........failed
[ 747.220017] bttv0: timeout: drop=0 irq=0/0, risc=ffffffff, bits: FMTCHG VSYNC HSYNC OFLOW HLOCK VPRES 6 7 I2CDONE GPINT 10 RISCI FBUS FTRGT FDSR PPERR RIPERR PABORT OCERR SCERR
