1.19.0 bugs
Posted: Thu Mar 18, 2004 1:21 pm
instalation from zero on mdk 10 final "btw 1.18.1 works fine on mdk 10 final"
i have a problem with "make"
In file included from zm_remote_camera.h:42,
from zm_remote_camera.cpp:39:
zm_regexp.h:27:23: pcre/pcre.h: No such file or directory
zm_regexp.h:32: error: syntax error before `*' token
zm_regexp.h:33: error: syntax error before `*' token
zm_remote_camera.cpp: In member function `int RemoteCamera::GetResponse()':
zm_remote_camera.cpp:274: error: `PCRE_DOTALL' undeclared (first use this function)
zm_remote_camera.cpp:274: error: (Each undeclared identifier is reported only once for each function it appears in.)
zm_remote_camera.cpp:282: error: `PCRE_MULTILINE' undeclared (first use this function)
zm_remote_camera.cpp:282: error: `PCRE_CASELESS' undeclared (first use this function)
make[2]: *** [zm_remote_camera.o] Error 1
make[2]: Leaving directory `/root/zm-1.19.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/zm-1.19.0'
make: *** [all] Error 2
[root@localhost zm-1.19.0]#
maybe is a problem with a libreries i dont have.. "still searching"
configure: WARNING: libavcodec.a is required for MPEG streaming
checking for av_new_stream in -lavformat... no
configure: WARNING: libavformat.a is required for MPEG streaming
checking for lame_init in -lmp3lame... no
configure: WARNING: libmp3lame.a may be required for IE compatible MPEG streaming
Fernando.
Fernando.
