Page 1 of 1
Error while shutdown or reboot
Posted: Mon Sep 13, 2010 12:57 am
by bumann
Hi!
During i shutdown or reboot my box the error message is displayed:
Stopping Zoneminder: DBI connect('database=zm;host=localhost',zmuser#,...) failed:
Can't connect to local MySQL server through socket '/var/run/mysqld/mysyld.ock'
(2) at /usr/share/perl5/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/share/perl5/ZoneMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
BEGINN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmpkg.pl line 45.
BEGINN failed--compilation aborted at /usr/bin/zmpkg.pl line 45.
Zoneminder already stopped
But when i STOP ZoneMinder during the Box is running, there is no error.
ZoneMinder is working good when the box is running . But I want to have no error messages in my system.
It runs on Ubuntu server 10.4!
Can anybody help me please?!
Greetings from Germany
Posted: Mon Sep 13, 2010 11:15 am
by bumann
No idea?
Re: Error while shutdown or reboot
Posted: Mon Sep 13, 2010 8:32 pm
by vanbosco
bumann wrote:Hi!
Same problem here with xubuntu 10.04 and 10.10.
This error cause to have a lot of "new event", one more for every video source on every reboot.
I think that the problem is that mysql stop before zm but i don't have find a way to change the order of stopping these services during reboot.
With *buntu 9.10 everythings is working fine.
Posted: Mon Sep 13, 2010 9:16 pm
by bumann
Thx for the info!
I canged to Debian ...
Error reboot/restart!
Posted: Tue Sep 21, 2010 1:21 pm
by redebeer
Only recently have i started experiencing this same issue.
If i hit ctrl+alt+F7 after bootup i get the same thing at startup...to which i also have to start ZM manually...i do this by entering a line into the local startup script of ubuntu (the sleep thing doesnt work for me)...
But yeah...it is a matter of mysql starting/stopping to early/late or to close to ZM starting
If someone finds/has a cure/workaround, please assist!!!
Posted: Tue Sep 21, 2010 1:44 pm
by mastertheknife
Yeah, it seems MySQL is shutting down before ZM.
Maybe its possible to change the order of shutdown, but it varies from distro to distro.
shutdown order
Posted: Sun Sep 26, 2010 2:09 am
by pdanilchik
Isn't the shutdown order just set by the symbolic links at /etc/rc0.d/ ? And the reboot ones at /etc/rc6.d/ for reboot ?? The only thing is... I don't see a symbolic link to shut down mysql so likely it is happening external to this before everything else? !? Or possibly the error has to do with network/filesystem sockets being closed ahead of ZM shutting down??
Has anyone tried renaming any to change the order of execution to see if the problem goes away? I would try but am unable to physically get to my server if something went awry (can't risk it now).
If a solution exists it would be great to know the specifics of what worked. I too see those errors (Ubuntu 10.04 LTS Server AMD64 with ZM 1.24.2).
Posted: Wed Oct 13, 2010 3:54 am
by ccisadmin
You just need to shutdown zoneminder before mysqld.
For centos 5 .. this worked for me:
cd /etc/rc6.d/
ln -s /etc/init.d/zm K33zm
workaround
Posted: Fri Dec 24, 2010 5:10 pm
by vanbosco
On my system with ubuntu 10.10 this change of /etc/init/mysql.conf solve the problem.
# MySQL Service
description "MySQL Server"
author "Mario Limonciello <superm1@ubuntu.com>"
start on (net-device-up
and local-filesystems
and runlevel [2345])
stop on runlevel [016]
respawn
env HOME=/etc/mysql
umask 007
# The default of 5 seconds is too low for mysql which needs to flush buffers
kill timeout 300
pre-start script
#Sanity checks
[ -r $HOME/my.cnf ]
[ -d /var/run/mysqld ] || install -m 755 -o mysql -g root -d /var/run/mysqld
# Load AppArmor profile
if aa-status --enabled 2>/dev/null; then
apparmor_parser -r /etc/apparmor.d/usr.sbin.mysqld || true
fi
LC_ALL=C BLOCKSIZE= df --portability /var/lib/mysql/. | tail -n 1 | awk '{ exit ($4<4096) }'
end script
exec /usr/sbin/mysqld
post-start script
for i in `seq 1 30` ; do
/usr/bin/mysqladmin --defaults-file="${HOME}"/debian.cnf ping && {
exec "${HOME}"/debian-start
# should not reach this line
exit 2
sleep 1
done
exit 1
end script
pre-stop script
# wait 30 sec for zoneminder to stop
if [ -e /var/lock/zm ] ; then
sleep 1
fi
done
end script
I have added the pre-stop script that wait for at least 30 second to stop mysql if zm is running.
