Hello everybody!
I'm trying to use an outdoor logitech camera and i can't find the adress of the video flux.
Does anybody use this kind of camera?
thanks for help!
Logitech outdoor add-on security camera
Depends on what model obviously.
One linksys that I have working on v1.24.2 is;
General -> Type: ffmpeg
Source ->
Path: http://10.0.0.100/img/video.asf
Colours: 24 bit
Width: 640
Height: 480
But don't get your hopes up too high. Linksys make crap cameras. Quality and reliability is poor.
Source ->
Colours: 24 bit
Width: 640
Height: 480
thanks for your answer but it's not a linksys camera it's a logitech camera
this is this one :
http://www.logitech.com/fr-fr/webcam-co ... tion=specs
it's used with a CPL adapter but it's transparent for ubuntu
I can ping it so the ip adress and the subnet mask is ok but i can't have a picture so I think the problem is about the path.
I've already read this post but the path is not clear for me..
http://www.zoneminder.com/forums/viewto ... cad06fc792
I have read the wiki (http://www.zoneminder.com/wiki/index.ph ... rk_Cameras) about supported hardware but there is nothing about logitech network camera
this is this one :
From the link you provided:
Disable user authentication (User Access Control?) in the camera firmware
select the java view mode in the camera firmware
Set width height values to 320*240
Set up monitor with these values
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: XXX.XXX.XXX.XXX
Remote Host Port: 80
Remote Host Path: /video.cgi?a=.mjpg
Capture Width (pixels): 320
Capture Height (pixels): 240
I also have a Logitech Outdoor Camera and I can not find the path to capture the video stream with zoneminder.
I set zoneminder as indicated bb99 but it doesn't work.
http://172.29.37.51/video.cgi?a=.mjpg no returns "HTTP/1.0 404 - File Not Found"
Thank you for your help!
