Page 1 of 1
Logitech outdoor add-on security camera
Posted: Wed Sep 15, 2010 12:57 pm
by pem
Hello everybody!
I'm trying to use an outdoor logitech camera and i can't find the adress of the video flux.
Does anybody use this kind of camera?
thanks for help!
Posted: Thu Sep 16, 2010 8:10 am
by Flasheart
Depends on what model obviously.
One linksys that I have working on v1.24.2 is;
General -> Type: ffmpeg
Source ->
Path:
http://10.0.0.100/img/video.asf
Colours: 24 bit
Width: 640
Height: 480
But don't get your hopes up too high. Linksys make crap cameras. Quality and reliability is poor.
Posted: Thu Sep 16, 2010 12:12 pm
by pem
thanks for your answer but it's not a linksys camera it's a logitech camera
this is this one :
http://www.logitech.com/fr-fr/webcam-co ... tion=specs
it's used with a CPL adapter but it's transparent for ubuntu
I can ping it so the ip adress and the subnet mask is ok but i can't have a picture so I think the problem is about the path.
I've already read this post but the path is not clear for me..
http://www.zoneminder.com/forums/viewto ... cad06fc792
I have read the wiki (
http://www.zoneminder.com/wiki/index.ph ... rk_Cameras) about supported hardware but there is nothing about logitech network camera
Posted: Sun Sep 19, 2010 8:49 am
by pem
hello everybody,
I've tried this kind of path :
rtsp://xxx.xxx.xxx.xxx/video.cgi?a=.mjpg
without succes.. does anybody have an idea?
Nobody use this kind of camera?
Posted: Sun Sep 19, 2010 11:59 am
by bb99
From the link you provided:
Disable user authentication (User Access Control?) in the camera firmware
select the java view mode in the camera firmware
Set width height values to 320*240
Set up monitor with these values
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: XXX.XXX.XXX.XXX
Remote Host Port: 80
Remote Host Path: /video.cgi?a=.mjpg
Capture Width (pixels): 320
Capture Height (pixels): 240
Posted: Fri Sep 24, 2010 7:16 am
by pem
thank you very much for your answer, I will try and I hope it's works!
Posted: Mon Jan 10, 2011 1:01 pm
by Toutella
I also have a Logitech Outdoor Camera and I can not find the path to capture the video stream with zoneminder.
I set zoneminder as indicated bb99 but it doesn't work.
http://172.29.37.51/video.cgi?a=.mjpg no returns "HTTP/1.0 404 - File Not Found"
Thank you for your help!
Posted: Wed Jan 12, 2011 9:48 am
by Toutella
Up ?
Posted: Thu Jan 13, 2011 7:34 am
by Flash_
pem wrote:thanks for your answer but it's not a linksys camera it's a logitech camera
Doh! Sorry, totally misread what you said!
