I have a network camera Airlive OD-325HD and I use Ubuntu 10.04 and Zoneminder 1.24.2.
I managed to set up the camera for mjpeg streaming with the following settings (monitor color in zoneminder is amber, which indicates that not everything is OK)
Source Type: Remote
Function: Monitor
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: admin:airlive@192.168.1.150
Remote Host Port: 80
Remote host Path: /mjpeg/video.mjpg
The problem is when I try to set up camera for mpeg4 streaming:
Source Type: Remote
Function: Monitor
Remote Protocol: RTSP
Remote Method: RTP/Unicast
Remote Host Port: 554
Remote host Path: /mpeg4/1/media.amp
In this case I get broken link and "Waiting for local host..." in Firefox status line.
I tested rtsp stream with Totem and VLC and it works fine.
Does anybody have any suggestion what might be wrong?
This is my zm_debug log:
09/19/10 08:12:51.094059 zmc_m1[5387].INF-zm_debug.c/292 [New Debug Level = 4, New Debug Log = /tmp/zm_debug.log.05387]
09/19/10 08:12:51.094363 zmc_m1[5387].DB1-zm_monitor.cpp/2262 [Got 1 monitors]
09/19/10 08:12:51.094663 zmc_m1[5387].DB1-zm_thread.cpp/241 [Creating thread]
09/19/10 08:12:51.094712 zmc_m1[5387].DB2-zm_rtsp.cpp/187 [RTSP Local SSRC is 34931c67]
09/19/10 08:12:51.094733 zmc_m1[5387].DB1-zm_thread.cpp/280 [Starting thread]
09/19/10 08:12:51.094829 zmc_m1[5388].DB2-zm_thread.cpp/253 [Invoking thread]
09/19/10 08:12:51.094864 zmc_m1[5387].DB1-zm_thread.cpp/301 [Started thread 5388]
09/19/10 08:12:51.100967 zmc_m1[5387].DB1-zm_monitor.cpp/338 [monitor purpose=1]
09/19/10 08:12:51.101003 zmc_m1[5387].DB1-zm_monitor.cpp/345 [mem.size=36865192]
09/19/10 08:12:51.124496 zmc_m1[5387].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
09/19/10 08:12:51.149218 zmc_m1[5387].DB1-zm_monitor.cpp/458 [Monitor Monitor-1 has function 2]
09/19/10 08:12:51.149255 zmc_m1[5387].DB1-zm_monitor.cpp/459 [Monitor Monitor-1 LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
09/19/10 08:12:51.149279 zmc_m1[5387].DB1-zm_monitor.cpp/460 [Monitor Monitor-1 IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
09/19/10 08:12:51.149423 zmc_m1[5387].DB1-zm_zone.cpp/889 [Got 1 zones for monitor Monitor-1]
09/19/10 08:12:51.149446 zmc_m1[5387].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 639,0 639,479 0,479']
09/19/10 08:12:51.149464 zmc_m1[5387].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
09/19/10 08:12:51.149480 zmc_m1[5387].DB3-zm_zone.cpp/796 [Got coordinate 639,0 from polygon string]
09/19/10 08:12:51.149496 zmc_m1[5387].DB3-zm_zone.cpp/796 [Got coordinate 639,479 from polygon string]
09/19/10 08:12:51.149512 zmc_m1[5387].DB3-zm_zone.cpp/796 [Got coordinate 0,479 from polygon string]
09/19/10 08:12:51.149532 zmc_m1[5387].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
09/19/10 08:12:51.149550 zmc_m1[5387].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:9216, MxAP:230400, FB:3x3, MnFP:9216, MxFP:230400, MnBS:6144, MxBS:0, MnB:1, MxB:0, OF: 0]
09/19/10 08:12:51.170936 zmc_m1[5387].DB1-zm_monitor.cpp/2459 [Loaded monitor 1(Monitor-1), 1 zones]
09/19/10 08:12:51.170977 zmc_m1[5387].INF-zmc.cpp/188 [Starting Capture]
09/19/10 08:12:51.171184 zmc_m1[5387].DB2-zm_remote_camera_rtsp.cpp/112 [Waiting for sources]
09/19/10 08:12:54.108097 zmc_m1[5388].ERR-zm_comms.cpp/276 [connect(), errno = 113, error = No route to host]
09/19/10 08:12:54.108181 zmc_m1[5388].FAT-zm_rtsp.cpp/208 [Unable to connect RTSP socket]
09/19/10 08:12:54.108277 zmc_m1[5388].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
