Changing user/group setting of apache fixed install problems
robolo
Post by robolo »
I had a working install of Zoneminder (ver 1.23.3) on the same computer as Centos 5 and also running Aster*sk. I tried to upgrade to zm 1.24.2 and immediately ran into problems. Trying to open the web console I get a "Couldn't open config" message. Then I was getting camera opening errors in the logs, errors with access to /dev/video, and an error with the web console always showing the ZoneMinder status as "Stopped" even when it was running.
I tried to wipe all old zm files, install new from scratch, even tried to reinstall old version of zm and nothing was working.
Eventually I figured out the problem was with the apache (httpd) service user/group settings. Through the previous installation of the other program on the computer the apache service had been configured with a different user/group name than "apache".
All I had to do was install zm with the options --with-webuser=<existing apache user name> --with-webgroup=<existing apache group name> and then everything worked perfectly.
This would not be a solution to anybody with a fresh computer setup since in that case apache would still be configured as having the default name "apache" for the user and group; but if you have a preexisting program and experience problems with zm installation (upgrade or new install) it might be worthwhile to double check the user/group name of the apache service.
Hope this helps somebody.
jjmz
Post by jjmz »
thanks for the pointer.. Is there any easy way to make this change in a config file or script - I used apt-get install to install zoneminder - would appreciate any pointers on where to change the webuser..
jjmz
Post by jjmz »
/etc/zm.conf or /etc/zm/zm.conf
robolo
Post by robolo »
Under Centos it is in /usr/local/etc/zm.conf
But I don't know that making this change after ZM is installed will help. When I had the incorrect apache user/group during install I was getting error messages.
Robert
