i have an Debian 5.0 Lenny Server, with an ZoneMinder installation.
ZoneMinder is Version 1.24.2.
Configuration from the Camera ACTi ACM 4201:
- Streaming method: RTP over UDP
RTSP Authen Enable: NOT ENABLED
B2 Frame Enable: NOT ENABLED
Audio in: Enabled (but you can choose either)
Input Sensitivity: Select whatever you want
Resolution: 352x288
Frame Rate Method: Constant
Frame rate: 25
Encoder type: MPEG4
Video Bitrate Mode: Variable Bit Rate
Video Quality: Middle
GOP Length: 0
RTSP Port: 7070
Video Control Port: 6001
General Tab
- Name: Camera1
Source Type: Remote
Function: Modect
Enabled (true/ticked)
Linked Monitors
Maximum FPS: 25
Alarm Max FPS: 25
Reference Image Blend %ge: 7
- Remote Protocol: RTSP
Remote Method: RTP/Unicast
Remote host name: my camera ip
Remote Host port: 7070
Remote Host Path: live.sdp
Capture Width: 352
Capture height: 288
Preserve aspect ration: ticked
Orientation: your choice
But in ZoneMinder i have only en empty rectangle and in the camera settings on "Probe" is the report:
"Unable to probe network cameras, status is '127'".
The Colors of "Function" and "Source" are green.
I have found in this forum the Thread "Unable to probe network cameras, status is '127''" http://www.zoneminder.com/forums/viewto ... status+127 but this is with no helpfully answer...
Thanks for help and sorry for my bad english
