Images are not ZM bt878 16
Posted: Thu Sep 23, 2010 9:05 pm
my card for 16 cameras
I see only blank images zm
ubuntu 10.4
kernel 2.6.32-25-generic
07:03.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22/A IEEE-1394a-2000 Controller (PHY/Link)
08:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
08:0c.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
08:0d.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
08:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
08:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
08:0e.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
08:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
08:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
[/quote]
scanpci
ubuntu 10.4
[/quote]
scanpci
xawtv -hwscanstruments TSB43AB22/A IEEE-1394a-2000 Controller (PHY/Link)
dmesgThis is xawtv-3.95.dfsg.1, running on Linux/i686 (2.6.32-24-generic)
looking for available devices
port 313-344
type : Xvideo, image scaler
name : NV17 Video Texture
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
name : BT878 video (Kodicom 4400R (sla
flags: overlay capture
/dev/video1: OK [ -device /dev/video1 ]
type : v4l2
name : BT878 video (Kodicom 4400R (mas
/dev/video2: OK [ -device /dev/video2 ]
type : v4l2
/dev/video3: OK [ -device /dev/video3 ]
type : v4l2
PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 12.721648] NVRM: loading NVIDIA UNIX x86 Kernel Module 195.36.15 Thu Mar 11 21:41:46 PST 2010
[ 12.746394] Console: switching to colour frame buffer device 80x30
[ 12.782959] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input4
[ 12.793841] HDA Intel 0000:01:00.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 12.793844] hda_intel: Disable MSI for Nvidia chipset
[ 12.793876] HDA Intel 0000:01:00.1: setting latency timer to 64
[ 12.891282] usbcore: registered new interface driver hiddev
[ 12.904273] input: 2.4G Wireless Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input5
[ 12.904410] generic-usb 0003:1D57:0008.0001: input,hidraw0: USB HID v1.10 Mouse [2.4G Wireless Optical Mouse] on usb-0000:00:1d.0-1/input0
[ 12.904429] usbcore: registered new interface driver usbhid
[ 12.904452] usbhid: v2.6:USB HID core driver
[ 13.641315] Linux video capture interface: v2.00
[ 13.673033] bttv: driver version 0.9.18 loaded
[ 13.673036] bttv: using 16 buffers with 2080k (520 pages) each for capture
[ 13.673847] bttv: Bt8xx card found (0).
[ 13.673868] bttv 0000:08:0c.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 13.673884] bttv0: Bt878 (rev 17) at 0000:08:0c.0, irq: 21, latency: 32, mmio: 0x93107000
[ 13.673902] bttv0: using: Tibet Systems 'Progress DVR' CS16 [card=131,insmod option]
[ 13.673904] IRQ 21/bttv0: IRQF_DISABLED is not guaranteed on shared IRQs
[ 13.673933] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 13.674300] bttv0: tuner absent
[ 13.674558] bttv0: registered device video0
[ 13.674778] bttv0: registered device vbi0
[ 13.674809] bttv0: PLL: 28636363 => 35468950 .
[ 13.680742] bttv0: PLL: 28636363 => 35468950 .
[ 13.680964] bttv0: PLL: 28636363 => 35468950 .. ok
[ 13.696519] ok
[ 13.704012] ok
[ 13.707448] bttv: Bt8xx card found (1).
[ 13.707458] bttv 0000:08:0d.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 13.707466] bttv1: Bt878 (rev 17) at 0000:08:0d.0, irq: 22, latency: 32, mmio: 0x93105000
[ 13.707477] bttv1: using: Tibet Systems 'Progress DVR' CS16 [card=131,insmod option]
[ 13.707478] IRQ 22/bttv1: IRQF_DISABLED is not guaranteed on shared IRQs
[ 13.707499] bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 13.707550] bttv1: tuner absent
[ 13.707592] bttv1: registered device video1
[ 13.707633] bttv1: registered device vbi1
[ 13.707654] bttv1: PLL: 28636363 => 35468950 .. ok
[ 15.914345] type=1505 audit(1285324619.992:5): operation="profile_load" pid=908 name="/usr/sbin/mysqld"
[ 15.997498] type=1505 audit(1285324620.076:6): operation="profile_load" pid=1016 name="/usr/share/gdm/guest-session/Xsession"
[ 15.998564] type=1505 audit(1285324620.076:7): operation="profile_replace" pid=1017 name="/sbin/dhclient3"
[ 15.999022] type=1505 audit(1285324620.076:8): operation="profile_replace" pid=1017 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 15.999266] type=1505 audit(1285324620.076:9): operation="profile_replace" pid=1017 name="/usr/lib/connman/scripts/dhclient-script"
[ 16.001386] type=1505 audit(1285324620.080:10): operation="profile_load" pid=1018 name="/usr/bin/evince"
[ 16.009437] type=1505 audit(1285324620.088:11): operation="profile_load" pid=1018 name="/usr/bin/evince-previewer"
[ 16.108148] e1000e 0000:00:19.0: irq 30 for MSI/MSI-X
[ 16.164042] e1000e 0000:00:19.0: irq 30 for MSI/MSI-X
[ 16.164227] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.618718] vboxdrv: Trying to deactivate the NMI watchdog permanently...
[ 45.896050] bttv2: Bt878 (rev 17) at 0000:08:0e.0, irq: 23, latency: 32, mmio: 0x93103000
[ 45.896080] bttv2: using: Tibet Systems 'Progress DVR' CS16 [card=131,insmod option]
[ 45.896082] IRQ 23/bttv2: IRQF_DISABLED is not guaranteed on shared IRQs
[ 45.896106] bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 45.896231] bttv2: tuner absent
[ 45.896577] bttv2: registered device video2
[ 45.896824] bttv2: registered device vbi2
[ 45.896847] bttv2: PLL: 28636363 => 35468950 .
[ 45.897222] bttv2: PLL: 28636363 => 35468950 .
[ 45.897295] bttv2: PLL: 28636363 => 35468950 .. ok
[ 45.912741] ok
[ 45.928024] ok
[ 78.088530] bttv: Bt8xx card found (3).
[ 78.088548] bttv 0000:08:0f.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 78.088559] bttv3: Bt878 (rev 17) at 0000:08:0f.0, irq: 20, latency: 32, mmio: 0x93101000
[ 78.088590] bttv3: using: Tibet Systems 'Progress DVR' CS16 [card=131,insmod option]
[ 78.088593] IRQ 20/bttv3: IRQF_DISABLED is not guaranteed on shared IRQs
[ 78.088624] bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 78.088741] bttv3: tuner absent
[ 78.089227] bttv3: registered device video3
[ 78.089315] bttv3: registered device vbi3
[ 78.089339] bttv3: PLL: 28636363 => 35468950 .
[ 78.089734] bttv3: PLL: 28636363 => 35468950 .
[ 78.089877] bttv3: PLL: 28636363 => 35468950 .. ok
[ 78.108010] ok
[ 78.120516] ok
[ 6159.138061] bttv0: PLL can sleep, using XTAL (28636363).
[ 6173.976443] __ratelimit: 18 callbacks suppressed
[ 6173.976448] cheese[7987]: segfault at 0 ip (null) sp b49f8f9c error 4 in libxml2.so.2.7.6[110000+124000]
