Reset button on the filters window
Yokav
Post by Yokav »
The "Reset" button on the filters window seems to don't work.
I create some filters, then I click on "Reset". For me it should remove all the filters that I created but nothing happen. The page seems to be reload but all the filters are still there.
cordel
Post by cordel »
The reset button only clears the page, it does not and is not ment to remove any saved filters.
Yokav
Post by Yokav »
Yes I known, I don't use it for removing the saved filters, I just tried with it to clear the page but it didn't work.
