Axis 216MFD intermittent image corruption
dbosso
Post by dbosso »
I've got an Axis 216MFD that I'm accessing via mpeg4 RTSP @ 1280x1024.
The problem is that the image occassionally looks like this for minutes at a time:
...then returns to normal. Accessing the camera directly when ZoneMinder is showing the corrupt image gives a normal one, so it appears to be something in ZM.
Does this ring any bells for anyone?
6 other lower res Axis cameras are working fine on this system.
Thanks.
-David
kingofkya
Post by kingofkya »
Thouse are mpeg artifacts this happens when the stream is interrupted you may need up upgrade your network switch or Cables between the camera.
