super high frame rates
jondecker76
Post by jondecker76 »
I have 2 different cameras connected to ZM.
Both of them are streaming in MJPEG. In the camera setup for each camera, I have set it to 15 FPS.
In ZM, it will show anywhere from 50 to over 300 FPS. I have only been using ZM for about a week, but it always used to hang at the set 15 FPS. Somehow, something has changed somewhere that is giving me these huge FPS readings all of the sudden.
Does anybody have any clue what could be the problem?
jondecker76
Not sure how it happened, but I also noticed that my load went up from about 0.8 to over 3.0 while the framerate was all goofy. Also, recordings were very odd, with the timestamp bobbling all over the place.
Anyways, did a reboot of my server and everything went back to normal.
bumann
Post by bumann »
I think you must set the frames inside of the cams webui and delete the framerate in the zm monitor settings ...
