VPON 4 input BT878 cards
Posted: Sun Oct 10, 2010 12:04 am
Using 4 of these cards, but I'm not sure how to set them up. Modprobe seems to sit at a blinking cursor forever. Can anyone give me some tips? I already added bttv.conf to /etc/modprobe.d, but I'm not sure which card type to use.
Here is my lspci info:
00:00.0 Host bridge: ALi Corporation M1689 K8 Northbridge [Super K8 Single Chip]
Subsystem: Giga-byte Technology Device 5000
Flags: bus master, fast devsel, latency 0
Memory at <ignored> (32-bit, prefetchable)
Capabilities: [40] HyperTransport: Slave or Primary Interface
Capabilities: [60] HyperTransport: Interrupt Discovery and Configuration
Capabilities: [80] AGP version 3.0
Kernel driver in use: agpgart-amd64
00:01.0 PCI bridge: ALi Corporation AGP8X Controller (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, fast devsel, latency 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
Memory behind bridge: e8000000-e9ffffff
Prefetchable memory behind bridge: e0000000-e7ffffff
Kernel modules: shpchp
00:02.0 PCI bridge: ALi Corporation M5249 HTT to PCI Bridge (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=02, subordinate=06, sec-latency=32
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: ea000000-ea0fffff
Prefetchable memory behind bridge: ea100000-ea4fffff
00:03.0 ISA bridge: ALi Corporation M1563 HyperTransport South Bridge (rev 70)
Subsystem: Giga-byte Technology Device 5001
Flags: bus master, medium devsel, latency 32
Kernel driver in use: ali1563_smbus
Kernel modules: i2c-ali1563
00:03.1 Bridge: ALi Corporation M7101 Power Management Controller [PMU]
Subsystem: Giga-byte Technology Device 5003
Flags: medium devsel
Kernel modules: alim7101_wdt, i2c-ali15x3, i2c-ali1535
00:0e.0 IDE interface: ALi Corporation M5229 IDE (rev c7) (prog-if fa)
Subsystem: Giga-byte Technology Device 5002
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 19
I/O ports at 01f0
I/O ports at 03f4
I/O ports at 0170
I/O ports at 0374
I/O ports at f000
Kernel driver in use: pata_ali
Kernel modules: pata_ali
00:0e.1 IDE interface: ALi Corporation ULi 5289 SATA (rev 10) (prog-if 8f [Master SecP SecO PriP PriO])
Subsystem: Giga-byte Technology Device b003
I/O ports at d000
I/O ports at d400
I/O ports at d800
I/O ports at dc00
I/O ports at e000
Kernel driver in use: sata_uli
Kernel modules: sata_uli
00:0f.0 USB Controller: ALi Corporation USB 1.1 Controller (rev 03) (prog-if 10 [OHCI])
Subsystem: Giga-byte Technology Device 5004
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 20
Memory at ea500000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
00:0f.1 USB Controller: ALi Corporation USB 1.1 Controller (rev 03) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 21
Memory at ea501000 (32-bit, non-prefetchable) [size=4K]
00:0f.2 USB Controller: ALi Corporation USB 1.1 Controller (rev 03) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 22
Memory at ea502000 (32-bit, non-prefetchable) [size=4K]
00:0f.3 USB Controller: ALi Corporation USB 2.0 Controller (rev 01) (prog-if 20 [EHCI])
Flags: bus master, 66MHz, medium devsel, latency 48, IRQ 23
Memory at ea503000 (32-bit, non-prefetchable) [size=256]
Capabilities: [50] Power Management version 2
Capabilities: [58] Debug port: BAR=1 offset=0090
Kernel driver in use: ehci_hcd
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
Flags: fast devsel
Capabilities: [80] HyperTransport: Host or Secondary Interface
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
Flags: fast devsel
Kernel modules: amd64_edac_mod
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
Flags: fast devsel
Kernel driver in use: k8temp
Kernel modules: k8temp
01:00.0 VGA compatible controller: nVidia Corporation NV11 [GeForce2 MX/MX 400] (rev b2) (prog-if 00 [VGA controller])
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 16
Memory at e8000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (32-bit, prefetchable) [size=128M]
[virtual] Expansion ROM at e9000000 [disabled] [size=64K]
Capabilities: [60] Power Management version 2
Capabilities: [44] AGP version 2.0
Kernel driver in use: nouveau
Kernel modules: nouveau, nvidiafb, rivafb
02:06.0 PCI bridge: Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev 11) (prog-if 00 [Normal decode])
Bus: primary=02, secondary=03, subordinate=03, sec-latency=32
Prefetchable memory behind bridge: ea100000-ea1fffff
Capabilities: [80] Power Management version 2
Capabilities: [90] CompactPCI hot-swap <?>
02:07.0 PCI bridge: Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev 11) (prog-if 00 [Normal decode])
Bus: primary=02, secondary=04, subordinate=04, sec-latency=32
Prefetchable memory behind bridge: ea200000-ea2fffff
02:08.0 PCI bridge: Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev 11) (prog-if 00 [Normal decode])
Bus: primary=02, secondary=05, subordinate=05, sec-latency=32
Prefetchable memory behind bridge: ea300000-ea3fffff
02:09.0 PCI bridge: Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev 11) (prog-if 00 [Normal decode])
Bus: primary=02, secondary=06, subordinate=06, sec-latency=32
Prefetchable memory behind bridge: ea400000-ea4fffff
02:0a.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: Giga-byte Technology GA-7VM400M/7VT600 Motherboard
Flags: bus master, medium devsel, latency 64, IRQ 18
I/O ports at c000 [size=256]
Memory at ea000000 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: 8139too
Kernel modules: 8139too, 8139cp
03:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 18
Memory at ea100000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
Kernel driver in use: bttv
Kernel modules: bttv
03:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 10
Memory at ea101000 (32-bit, prefetchable) [size=4K]
03:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 19
Memory at ea102000 (32-bit, prefetchable) [size=4K]
03:09.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 11
Memory at ea103000 (32-bit, prefetchable) [size=4K]
03:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 20
Memory at ea104000 (32-bit, prefetchable) [size=4K]
03:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 7
Memory at ea105000 (32-bit, prefetchable) [size=4K]
03:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 21
Memory at ea106000 (32-bit, prefetchable) [size=4K]
03:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 3
Memory at ea107000 (32-bit, prefetchable) [size=4K]
04:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at ea200000 (32-bit, prefetchable) [size=4K]
04:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea201000 (32-bit, prefetchable) [size=4K]
04:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at ea202000 (32-bit, prefetchable) [size=4K]
04:09.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea203000 (32-bit, prefetchable) [size=4K]
04:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at ea204000 (32-bit, prefetchable) [size=4K]
04:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea205000 (32-bit, prefetchable) [size=4K]
04:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 4
Memory at ea206000 (32-bit, prefetchable) [size=4K]
04:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea207000 (32-bit, prefetchable) [size=4K]
05:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at ea300000 (32-bit, prefetchable) [size=4K]
05:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea301000 (32-bit, prefetchable) [size=4K]
05:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at ea302000 (32-bit, prefetchable) [size=4K]
05:09.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea303000 (32-bit, prefetchable) [size=4K]
05:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at ea304000 (32-bit, prefetchable) [size=4K]
05:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea305000 (32-bit, prefetchable) [size=4K]
05:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at ea306000 (32-bit, prefetchable) [size=4K]
05:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea307000 (32-bit, prefetchable) [size=4K]
06:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at ea400000 (32-bit, prefetchable) [size=4K]
06:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea401000 (32-bit, prefetchable) [size=4K]
06:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at ea402000 (32-bit, prefetchable) [size=4K]
06:09.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea403000 (32-bit, prefetchable) [size=4K]
06:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at ea404000 (32-bit, prefetchable) [size=4K]
06:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea405000 (32-bit, prefetchable) [size=4K]
06:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 5
Memory at ea406000 (32-bit, prefetchable) [size=4K]
06:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at ea407000 (32-bit, prefetchable) [size=4K]
I/O ports at 01f0
I/O ports at 03f4
I/O ports at 0170
I/O ports at 0374
I/O ports at f000
I/O ports at d000
I/O ports at d400
I/O ports at d800
I/O ports at dc00
I/O ports at e000
Flags: fast devsel
Flags: fast devsel
Flags: fast devsel
Flags: fast devsel
