I Cant get working any camera Debian with Lenny
Posted: Sun Oct 17, 2010 12:01 pm
Hi guys,
I've been playing around with ZoneMinder for a while but i can't get working my IP camera, i've been looking and reading the wiki, i've tryed the shared memory trick and every think i found or figured out, but without luck.
This is my system:
ZoneMinder is working in the system and it looks just well. When i configure the camera using the JPG file mode i can't get any image, the viewer is black.
if i put this address in my browser i can get the camera image just fine:
When i start looking for a fix i found about the shared memory and i calculate the value for my system and increase the memory but it is still not working.
this is the te output with the command tail -f /tmp/zm*
And the messages from /var/log/
INFO:
WARNING:
I can't figure out why is not working, i'll apreciate any ideas or info that could be usefull!
Thanks you very much.
This is my system:
ZoneMinder 1.24.2
Linux Debian Lenny
Vivotek PT32x7 IP Camera
http://user:password@<ip>:<port>/cgi-bin/video.jpg
==> /tmp/zmfilter.log <08> /tmp/zmpkg.log <10> /tmp/zmupdate.log <08> /tmp/zmwatch.log <==
10/17/10 13:40:08.240819 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:40:18.243212 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:40:28.245504 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:40:38.247862 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:40:48.250408 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:40:58.252860 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:41:08.255369 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:41:18.257846 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:41:28.260364 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:41:38.262889 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:41:48.265341 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:41:58.267860 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
10/17/10 13:42:08.270332 zmwatch[28712].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
INFO:
Oct 17 13:13:11 jfp-dual zmc_m3[28922]: INF [Debug Level = 0, Debug Log = <none>]
Oct 17 13:13:11 jfp-dual zmdc[28682]: INF ['zmc -m 3' crashed, signal 6]
Oct 17 13:14:30 jfp-dual zmdc[28682]: INF [Starting pending process, zmc -m 1]
Oct 17 13:14:30 jfp-dual zmdc[28682]: INF ['zmc -m 1' starting at 10/10/17 13:14:30, pid = 28924]
Oct 17 13:14:30 jfp-dual zmdc[28924]: INF ['zmc -m 1' started at 10/10/17 13:14:30]
Oct 17 13:14:30 jfp-dual zmc_m1[28924]: INF [Debug Level = 0, Debug Log = <none>]
Oct 17 13:14:30 jfp-dual zmc_m1[28924]: INF [Starting Capture]
Oct 17 13:15:51 jfp-dual zmdc[28682]: INF [Starting pending process, zmc -m 3]
Oct 17 13:15:51 jfp-dual zmdc[28682]: INF ['zmc -m 3' starting at 10/10/17 13:15:51, pid = 28931]
Oct 17 13:15:51 jfp-dual zmdc[28931]: INF ['zmc -m 3' started at 10/10/17 13:15:51]
Oct 17 13:15:51 jfp-dual zmc_m3[28931]: INF [Debug Level = 0, Debug Log = <none>]
Oct 17 13:15:51 jfp-dual zmdc[28682]: INF ['zmc -m 3' crashed, signal 6]
Oct 17 13:21:11 jfp-dual zmdc[28682]: INF [Starting pending process, zmc -m 3]
Oct 17 13:21:11 jfp-dual zmdc[28682]: INF ['zmc -m 3' starting at 10/10/17 13:21:11, pid = 28958]
Oct 17 13:21:11 jfp-dual zmdc[28958]: INF ['zmc -m 3' started at 10/10/17 13:21:11]
Oct 17 12:45:21 jfp-dual zms[28735]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Oct 17 12:45:31 jfp-dual zmu[28737]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Oct 17 12:45:31 jfp-dual zmu[28739]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Oct 17 12:45:36 jfp-dual zms[28740]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Oct 17 12:48:51 jfp-dual zmdc[28682]: WAR [Can't find process with command of 'zmc -m 3']
Oct 17 12:48:52 jfp-dual zmdc[28682]: WAR [Can't find process with command of 'zma -m 3']
Oct 17 12:49:11 jfp-dual zmdc[28682]: WAR [Can't find process with command of 'zma -m 3']
Oct 17 12:49:38 jfp-dual zmdc[28682]: WAR [Can't find process with command of 'zma -m 3']
Oct 17 12:49:54 jfp-dual zmdc[28682]: WAR [Can't find process with command of 'zma -m 3']
Oct 17 13:10:05 jfp-dual zmdc[28682]: WAR [Can't find process with command of 'zma -m 3']
Oct 17 13:10:10 jfp-dual zms[28894]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Oct 17 13:10:10 jfp-dual zms[28894]: WAR [Unable to store frame as shared memory invalid]
Oct 17 13:10:37 jfp-dual zmdc[28682]: WAR [Can't find process with command of 'zma -m 3']
Oct 17 13:10:59 jfp-dual zms[28917]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Oct 17 13:10:59 jfp-dual zms[28917]: WAR [Unable to store frame as shared memory invalid]
