Page 1 of 1
Avermedia 16 port analog cards?
Posted: Mon Oct 18, 2010 8:03 pm
by butlerm1977
Are any of the 16 port cards listed on this page compatible with ZM? I'd be using CentOS 5.5 x64
http://www.averusa.com/surveillance/cat ... px?cid=114
NV6480E16
NV6240E16
NV8416 E4
NV7240
I do see that a few of the Aver cards are supported. I could not figure out what chipset the cards above run. So as a follow up question, what is a good 16 port card that can record at 240 or 480 fps that would play friendly with ZM out of the box.
Thanks!
Posted: Tue Oct 19, 2010 6:44 am
by kingofkya
Those are all techwell chips which are supported however the the drive has to be compiled and is kinda beta right now. Search techwell on the forum the thread will come up.
Posted: Tue Oct 19, 2010 4:34 pm
by butlerm1977
Is this the thread you are referring to ?
http://www.zoneminder.com/forums/viewtopic.php?t=14588
