Hi Guys,
Just upgraded to Ubuntu 10.04 and installed ZM via Synaptic and was pleased to discover it worked 'out of the box'.
So I went ahead and added an extra partition for image and event storage - so far so good.
The monitors text are green and are storing data as I desired to this new partition. I know this to be true by looking in the folders.
However Apache2 doesn't know where to look for these files. I've entered the path in the ZM options but I need to edit the Apache conf file to tell it where the root is.
The apache error log says can't find /var/www/var/...
I have not been able to find the apache2 or httpd conf files which contain the line pointing to /var/www.
Any pointers on this one as to which file to edit and where it's located ?
Thanks Tim
Extra HD added - question about apache config
Took the easy option....
and simply mounted the big storage partition at var/cache/zoneminder
Thanks anyway !
Tim
Thanks anyway !
Tim
