Page 1 of 1
Camera Issues on Debian Stretch (armel)
Posted: Mon Oct 25, 2010 10:39 pm
by bobbarker
I'm having an issue with setting up monitors on a ZM (1.24.2) install on my Seagate Dockstar using Debian Stretch. The camera I'm using is a Logitech C120, it's UVC and plays nice right out of the box with debian. I've used it with mjpg-streamer without any problems.
When I go to setup a monitor and go to probe I get an error:
Unable to probe local cameras, status is '137'
Which I've searched for and can't find *any* mentioning of it.
So I try to manually call zmu with
zmu -d /dev/video0 -V1 --query
Which just returns "Killed". I'm using the root account over ssh. Trying sudo I get nothing returned.
I cannot change to the source tab under the monitor settings. I also cannot delete the test monitor I created (it's setup looking for a /dev/video which doesn't exist so I get an error in the logs because of it).
When I run/restart zoneminder it always reports starting up fine, same with apache, mysql and php5...so...I dunno.
I'm guessing it's all just a permissions issue but I'm not savvy enough with linux to intuitively know how to fix it. Any thoughts?
Posted: Thu Oct 28, 2010 2:49 pm
by bobbarker
Anyone?
Posted: Fri Oct 29, 2010 8:25 am
by Flash_
I'm not sure entirely what you do, so this is quite woolly. The mention of /dev/video says it's a local camera mounted by linux, but mjpeg-streamer confuses it.
I don't use probe so can't advise there.
If it is local, find out where it is mounted in /dev/ (may be /dev/video1 video0 etc) and change that in the source.
If you're using mjpeg-streamer, is that accessible via http? Or are you saving as jpgs locally?
If former, you'll need to setup the camera as 'remote' and http://localhost/filename for the source.
If latter, use file (but ime, this way ends up with tears and half pictures as zm tries to read a file still being written)
Posted: Fri Oct 29, 2010 2:14 pm
by bobbarker
The camera is at /dev/video0. It's a Logitech C120 and it uses the standard UVC driver (bought it for just that reason).
My use of mjpg-streamer was just to test the local camera (it's a headless system, no video card what-so-ever). Didn't mean to be confusing there. I don't have mjpg-streamer running at all tying up the camera when I try and access it from ZoneMinder. Zoneminder just seems unable to check for cameras.
The only error codes I found online were '255' and '137' which typically involve network cameras-- not local ones (like mine is). Error 127 just doesn't seem to exist in any documentation/forum posts.
Posted: Fri Oct 29, 2010 4:26 pm
by jdhar
I've run a C120 on a head-less armel as well. You are sure you can view the feed? To test mine, I used VLC to pipe /dev/video0 to a feed I could view from another machine.
I had issues accessing the device directly with ZM as well (diff. than yours), so I setup VLC to stream /dev/video0 locally, and used ZM with the FFMPEG option to connect to it, and it worked fine. Not much diff. in load either. Maybe try a roundabout-ish way like that.
Posted: Mon Nov 01, 2010 1:21 pm
by bobbarker
Hmm. I'll try that. I can view an MJPG stream remotely using mjpg-streamer so I know the camera is setup fine as far as kmods go. Maybe I'll pipe that in to zoneminder.
