One port working on a Conexant Fusion 878A chip SOLVED
styro
Post by styro »
I solved this with a patch I found here: (http://osdir.com/ml/linux-media/2009-04/msg00479.html ) Wasn't able to patch with the utility 'patch' so I just patched it by hand. Then I compiled new kernel, and added card=77 in bttv.conf. You need to patch 3 files, CARDLIST.bttv, bttv.h and bttv-cards.c. If anyone needs help with this I will help as much as I can.
Styro
jvrramirez
Re: One port working on a Conexant Fusion 878A chip SOLVED
Post by jvrramirez »
yes please, I need help.
I have a stgv800, in the board say:sdvr607t
in the chips:fusion 878A
16cams
I have ubuntu 12
can you helpme?
thanks in advance
