Secure transmission and codec questions.
vethco
Post by vethco »
Hi everybody,
I'm new using zoneminder and i would like to have some informations about zoneminder 1.24.2 :
- Is it possible to encrypt transmission bitwin videocamera and zone minder server (in the case where server and cam are not in the same location) maybe use ssl ?
- Is the zoneminder server support H246 codec ?
- Is there a way to define media archieving duration (for exemple every records are delate after 7 days)
- Is it possible to add rule for web interface (for exemple admin have all right, titi have only camera view right) ?
In advance, thanks for your help.
kingofkya
Post by kingofkya »
yes it will suport ssl
yes but it will still record to jpegs
yes but it is recomended to only do when the hard drive is filled not by some weekly e vent ( but it is trival to do if need be)
yes you can assign users and permissions
vethco
Post by vethco »
Thanks kingofkya,
I think the informations to create users, configure permissions and other parameters i mentionned are in the Zoneminder manual or is there any tutorial or thinks like that where those configurations are better explaned.
Is there any minimum hardware specifications ?
Did anyone try use zm server with atom processor ? If yes, how does the atom react in a 24H/24H production environnement ?
Thanks.
