I have checked http://www.zoneminder.com/forums/viewtopic.php?p=54513
and my symptoms are similar but I believe the cause to be entirely different. I am a relative newbie to LINUX though so I don't want to lead astray.
While attempting to make I receive the following:
zm_ffmpeg.h:33: error: #error "No location for avutils.h found"
zm_ffmpeg.h:40: error: #error "No location for avcodec.h found"
zm_ffmpeg.h:47: error: #error "No location for avformat.h found"
zm_ffmpeg.h:55: error: #error "No location for swscale.h found"
I don't believe this to be in a wrong directory as I can't find them anywhere on the system. My ffmpeg install/make seemed to go fairly well.
Has anyone seen this or have any thoughts on the matter?
ffmmeg on new UBUNTU 10.10 install
Total newbie at security cam apps
Have a look at my installation script / instructions that I wrote for ZM on Ubuntu 10.10: http://www.zoneminder.com/forums/viewtopic.php?t=16628
It seems to me like you've tried to compile ZM from source without compiling and installing FFmpeg from source too.
It could also be that you forgot to add CPPFLAGS="-D__STDC_CONSTANT_MACROS" to the ZM configure script's command-line arguments, like I've said in 5. !! Note !!
