Been running Zoneminder on Fedora 13 for about a year now. Works perfectly!
Recently made a few changes along with an update of fedora 13 and suddenly my load is consistently over 1. I know 1 isn't bad but I am noticing that all the events that get recorded seem to be really slow during play back. Almost like it cant fit all the frames in quick enough.
Live view seems to be showing the information correctly but seems a little choppy.
I was running Fedora 13. The server being just home security system, I took it down and upgraded to Fedora 14. Hoping a fresh install and newer software might clean it up?
I'm just wondering if anyone else out there has been having the same problem? Or similar? Maybe its one Fedora module that got upgraded or something.
If anyone's interested I can post more details.
Wondering if anyone else has this problem?
Single Left system out?bb99 wrote:You can single left system monitor and check which process is dragging you down.
I've tried shutting different sections off like motion detection. Or specific monitors. It cuts off about 1/4 of the load. Which would make sence with 4 monitors.
Its a Core 2 Due 2.33 processor.. Didn't focus on that with the message because it was working in the machine before with a hitch.
Im running Fedora 64 Bit also, It was 64 bit before also.
