[SOLVE] Errors in Apache2
Mika
Post by Mika »
I Have Ubuntu 10.10, Apache2,MysqL 5 and PHP 5 work with ZoneMinder 1.24.2.
All work fine, but i get this error in this file /var/log/apache2/errors.log
[Thu Nov 11 20:30:52 2010] [error] [client 192.168.1.100] socket_sendto( /var/log/zm/zms-656693s.sock ) failed: No such file or directory, referer: http://192.168.1.2:8080/index.php?view=montage&group=0
[Thu Nov 11 20:30:52 2010] [error] [client 192.168.1.100] array (\n  0 => \n  array (\n    'file' => '/var/www/zm/ajax/stream.php',\n    'line' => 55,\n    'function' => 'ajaxError',\n    'args' => \n    array (\n      0 => 'socket_sendto( /var/log/zm/zms-656693s.sock ) failed: No such file or directory',\n    ),\n  ),\n  1 => \n  array (\n    'file' => '/var/www/zm/index.php',\n    'line' => 116,\n    'args' => \n    array (\n      0 => '/var/www/zm/ajax/stream.php',\n    ),\n    'function' => 'require_once',\n  ),\n), referer: http://192.168.1.2:8080/index.php?view=montage&group=0
The file /var/log/zm/zms-656693s.sock doesn't exists. I have 777 permision in /var/log/zm directory and www-data is owner of /var/log/zm
I see this error in other post, but don't resolve.
Can help me?
Thx
Mika
Re: Errors in Apache2
Post by Mika »
Mika wrote:Hi,
Can help me?
Thx
Ok, i fix this error.
Edit this file: /var/www/zoneminder/ajax/stream.php in line 49 you can see:
$max_socket_tries = 3;
Change for (5 or more):
$max_socket_tries = 5;
Thx
