Page 1 of 1
Zoneminder PTZ file for Vivotek PZ7131 (VivotekPZ7131.pm)
Posted: Wed Nov 17, 2010 7:03 am
by clumsy
Attached a PTZ file that works with the Vivotek PZ7131 IP cam (and probably similar Vivotek cams).
There are still so me improvements needed, however it works for relative movement, zoom and presets.
Credits and thanks to Normando Hall, as this script is derived from his work on the PT7135.
if you have any comments, improvements or questions, please let me know!
STefan
# This module contains the implementation of the Vivotek PZ7131 protocol
# Adapted from PT7135 module from Normando Hall nhall[AT]unixlan[DOT]com[DOT]ar !
# Thanks to him for his work. This module is published/changed with his agreement.
# Still work in progress not everything is working as it should (eg. Map).
# If you have any improvments, please let me know!
# STefan Mayer, stefan(at)clumsy(dot)ch
package ZoneMinder::Control::VivotekPZ7131;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Vivotek PZ7131 Control Protocol
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
# printMsg( $cmd, "Tx" );
Debug( "http://".$self->{Monitor}->{ControlAddress}."$cmd" );
if ( $res->is_success )
$result = !undef;
else
return( $result );
sub receiveCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
#printMsg( $cmd, "Rx" );
DEBUG( "http://".$self->{Monitor}->{ControlAddress}."$cmd" );
my $content = $res->content();
$result = $content;
else
return( $result );
sub reset
my $self = shift;
Debug( "Camera Reset" );
my $cmd = "/cgi-bin/admin/setparam.cgi?reset=3";
$self->sendCmd( $cmd );
# moveMap does not yet work!! Mapping from x/y coordinates to absolute coordinates of cam is not yet done
# also it's not clear on how to get the actual position of the cam.
sub moveMap
my $self = shift;
my $params = shift;
my $xcoord = $self->getParam( $params, 'xcoord' );
my $ycoord = $self->getParam( $params, 'ycoord' );
my $imagewidth = $self->{Monitor}->{Width};
my $imageheight = $self->{Monitor}->{Height};
Debug( "Move Map to $xcoord,$ycoord at $imagewidth/$imageheight" );
# if ( $imagewidth == "640" )
# $xcoord = $xcoord/2;t
# $ycoord = $ycoord/2;
# my $cmd = "/cgi-bin/admin/setparam.cgi?whitebalance=auto";
#Debug( "Delete temp position" );
#my $cmd = "/cgi-bin/operator/preset.cgi?delpos='goto_tmp'";
#$self->sendCmd( $cmd );
my $cmd = "/cgi-bin/admin/setparam.cgi?camctrl_c0_preset_i19_name=goto_tmp&camctrl_c0_preset_i19_pan=$xcoord&camctrl_c0_preset_i19_tilt=$ycoord";
Debug( "Recall stored temp position" );
$cmd = "/cgi-bin/camctrl/recall.cgi?recall=goto_tmp";
# Debug( "Delete Preset temp position" );
# $cmd = "/cgi-bin/operator/preset.cgi?delpos='goto_tmp'";
# $self->sendCmd( $cmd );
sub moveRelUp
my $self = shift;
my $params = shift;
my $tiltspeed = $self->getParam( $params, 'tiltspeed' );
Debug( "Move Up - Speed $tiltspeed" );
my $cmd = "/cgi-bin/viewer/camctrl.cgi?speedtilt=$tiltspeed";
sleep(2);
$cmd = "/cgi-bin/viewer/camctrl.cgi?move=up";
sub moveRelDown
my $self = shift;
my $params = shift;
Debug( "Move Down - Speed $tiltspeed" );
sleep(2);
$cmd = "/cgi-bin/viewer/camctrl.cgi?move=down";
sub moveRelLeft
my $self = shift;
my $params = shift;
my $panspeed = $self->getParam( $params, 'panspeed' );
Debug( "Move Left - Speed $panspeed" );
my $cmd = "/cgi-bin/viewer/camctrl.cgi?speedpan=$panspeed";
sleep(2);
$cmd = "/cgi-bin/viewer/camctrl.cgi?move=left";
sub moveRelRight
my $self = shift;
my $params = shift;
Debug( "Move Right - Speed $panspeed" );
sleep(2);
$cmd = "/cgi-bin/viewer/camctrl.cgi?move=right";
sub moveRelUpRight
my $self = shift;
my $params = shift;
Debug( "Move Up/Right - Speed $tiltspeed/$panspeed" );
my $cmd = "/cgi-bin/viewer/camctrl.cgi?speedtilt=$tiltspeed&speedpan=$panspeed";
sleep(2);
sub moveRelUpLeft
my $self = shift;
my $params = shift;
Debug( "Step Up/Left - Speed $tiltspeed/$panspeed" );
sleep(2);
sub moveRelDownRight
my $self = shift;
my $params = shift;
Debug( "Step Down/Right - Speed $tiltspeed/$panspeed" );
sleep(2);
sub moveRelDownLeft
my $self = shift;
my $params = shift;
Debug( "Step Down/Left - Speed $tiltspeed/$panspeed" );
sleep(2);
# sub whiteAuto
# my $self = shift;
# Debug( "White Auto" );
# sub whiteMan
# my $self = shift;
# Debug( "White Man" );
# my $cmd = "/cgi-bin/admin/setparam.cgi?whitebalance=2";
# sub In
# my $self = shift;
# Debug( "White In" );
# my $cmd = "/cgi-bin/admin/setparam.cgi?whitebalance=1";
# sub Out
# my $self = shift;
# Debug( "White Out" );
# my $cmd = "/cgi-bin/admin/setparam.cgi?whitebalance=3";
sub zoomRelTele
my $self = shift;
my $params = shift;
my $zoomspeed = $self->getParam( $params, 'speed' );
Debug( "Zoom Tele $zoomspeed" );
my $cmd = "/cgi-bin/viewer/camctrl.cgi?speedzoom=$zoomspeed";
sleep(2);
$cmd = "/cgi-bin/viewer/camctrl.cgi?zoom=tele";
sub zoomRelWide
my $self = shift;
my $params = shift;
Debug( "Zoom Wide $zoomspeed" );
sleep(2);
$cmd = "/cgi-bin/viewer/camctrl.cgi?zoom=wide";
sub presetClear
my $self = shift;
my $params = shift;
$preset = ( $preset - 1 );
Debug( "Clear Preset $preset" );
my $cmd = "/cgi-bin/operator/preset.cgi?delpos=$preset";
sub presetSet
my $self = shift;
my $params = shift;
#my $cmd = "/cgi-bin/admin/getparam.cgi?axisx";
#my $rx = $self->receiveCmd( $cmd );
#my ($axisx) = $rx =~ /([-0-9]+)/;
#$cmd = "/cgi-bin/admin/getparam.cgi?axisy";
#$rx = $self->receiveCmd( $cmd );
#my ($axisy) = $rx =~ /([-0-9]+)/;
Debug( "Delete Preset $preset at current position" );
Debug( "Set Preset $preset at current position" );
$cmd = "/cgi-bin/operator/preset.cgi?addpos=$preset";
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "/cgi-bin/camctrl/recall.cgi?recall=$preset";
sub presetHome
my $self = shift;
Debug( "Home Preset" );
my $cmd = "/cgi-bin/viewer/camctrl.cgi?move=home";
1;
__END__
