Page 1 of 1
admin user can do anything
Posted: Fri Nov 26, 2010 3:29 pm
by dafranlu
I have a new installaton, in order to protect it I added a password to my admin account and now everything is greyed out.
I can go everywhere but can't make any change either in the monitor parameter or in the option tab
I can't of course add any new users or cams ?
Any clue on how to "unlock" my admin account
Dafranlu
Posted: Fri Nov 26, 2010 7:36 pm
by jdhar
Go to Options and Users, and make sure your Admin user has all Edit permissions.
admin user can't do anything
Posted: Fri Nov 26, 2010 11:11 pm
by dafranlu
Unfortunately the admin user is as well greyed out
Shall I start a fresh install
Posted: Sat Nov 27, 2010 12:53 am
by jdhar
and this is your only user on the system? maybe somehow you locked yourself out of the appropriate permissions? Are you actually logged in as the admin usre (does it say 'admin' on the frontpage)? What does it show for your permissions under the User Panel? For example, Admin shows the followin for me:
admin* default Yes View Edit Edit Edit Edit
Worst case, you can change the permissions in the Mysql database. I can give you an example on how to do this if you don't know how.
Posted: Sun Nov 28, 2010 10:00 am
by Juniku
Excactly same problem, i even made new user and gave almost admin privileges to it, and same problem, can not add new monitor or edit any settings, buttons are greyed.
As far as i can remember i did not do any changes when this problem appeared, there was only 1hour delay when admin was logged in and then i logged in with my laptop and with that laptop i noticed this problem first time.
I installed Zoneminder yesterday with aptitude, from Debian own repositorys.
Posted: Sun Nov 28, 2010 11:39 am
by Juniku
I reinstalled Zoneminder, and now i cant get cameras work anymore like yesterday :evil:
But the original problem is still there, after reinstall, i was able to do anything what admin can do, but when i choosed "PT_USE_AUTH Authenticate user logins to ZoneMinder [ ]" and restarted ZoneMinder (/etc/init.d/zoneminder restart) everything was gray and were not able to do anything.
Luckily i had mysql dump so i fixed this very fast. What makes this? Why PT_USE_AUTH cannot be ON ?
