Page 1 of 1
cambozola.jar location
Posted: Wed Dec 01, 2010 1:44 pm
by barrydocks
where do I need to put this in order for streaming to work with IE?
Posted: Tue Jan 18, 2011 9:57 pm
by christophe_y2k
i put the .jar file in web root directory, the same place where you can found your zoneminder index.php typically /var/www/zoneminder/htdocs
Posted: Wed Feb 02, 2011 10:11 am
by barrydocks
still struggling with this, I have zoneminder V 1.24.2 running on Ubuntu Server 10.04.2 32bit.
I have copied cambozola.jar to both the /var/www and /usr/share/zoneminder directories but still no streaming in IE ?? I get a refresh every 3 to 4 seconds?
Help?
Posted: Wed Feb 02, 2011 2:18 pm
by insippo
IE is the 666 browser.Install ubuntu and use FF.
Posted: Fri Feb 04, 2011 9:16 am
by barrydocks
insippo wrote:IE is the 666 browser.Install ubuntu and use FF.
Installing ubuntu is not an option.
Posted: Fri Feb 04, 2011 6:57 pm
by insippo
Google Chome not show video in zm but FF works ok
Posted: Fri Feb 04, 2011 7:04 pm
by mastertheknife
barrydocks wrote:still struggling with this, I have zoneminder V 1.24.2 running on Ubuntu Server 10.04.2 32bit.
Help?
Have you enabled cambozola in your settings? And make sure your streaming type is jpeg and not mpeg.
Also, check if the cambozola.jar file is accessible by trying to download it by typing the link to your cambozola.jar in your web browser and trying to download it.
mastertheknife
Posted: Sat Mar 05, 2011 11:54 am
by barrydocks
mastertheknife wrote:Have you enabled cambozola in your settings?
That worked
