I wrote a Perl script to concatenate events using ffmpeg. The script finds the images from each Event and stages them for ffmpeg to use them to create the video. It skips images (frames) that might be duplicate, i.e. from when two Events overlap due to Pre and Post Event Image counts.
Anyone interested in using it you can get it and information on it here.
Any comments. questions, suggestions, let me know.
Concatenate ZoneMinder Events Utility
Well that certainly is embarrassing. It's in there now. Musta forgot to move it to the staging directory when I made the tarball. Sorry about that.Dreded wrote:so I went to go download your perl script and there is no perl script in the archive... also I had to use 7zip to even open what was there(Readme and ReleaseNotes) as any other archive manager said it was an invalid file
7zip? not familiar with that. You mean
tar -xvzf zmConcatEvents-1.0.0.tar.gz
Didn't work? Or
gzip -d zmConcatEvents-1.0.0.tar.gz
tar -xvf zmConcatEvents-1.0.0.tar
Didn't work for you? Both those methods work for me and I just tried them again. Let me know if you still have problems unzipping it.
coomand not found
afeter i extract tar archive in ../zm/zmConcatEvents-1.0.0
and cd .../zmConcatEvents-1.0.0
i get this
bash: zmConcatEvents: command not found
can you give me a clue?
i get this
Thanks!eronquillo wrote:Amazing job you did! Thank you so much for creating this script!
Learn UNIX/Linux?mmi wrote:afeter i extract tar archive in ../zm/zmConcatEvents-1.0.0
i get this
The zmConcatEvents-1.0.0 directory is not in your path so if you don't type in the fully qualified path and file name it's not going to be found.
Type ./zmConcatEvents when sitting in the directory where it exists.
