Recording events only
tibetfreedom
Post by tibetfreedom »
I have installed the latest SVN
I want to record only when the camera's detect movement and also send events to an FTP site…
I'm sure this is fairly simple…
Dreded
Post by Dreded »
you want to set the cameras to "modect" then and under Options > FTP tab check OPT_UPLOAD and fill in the various fields below
after that make a filter based on what you want to send to the FTP and hit "save" then save that filter and check "Run in Background" so it auto runs that filter every 5min(default)
I suggest reading the documentation... http://www.zoneminder.com/wiki/ then click "Documentation" on the left hand menu
tibetfreedom
Dreded wrote:you want to set the cameras to "modect" then and under Options > FTP tab check OPT_UPLOAD and fill in the various fields below
Thanks, is it possible to upload to FTP immediately upon some kind of notification ?
i.e. movement > Notifiaction >Upload to FTP …?
Also what is uploaded and how easy is it to view… ?
Thanks...
