Frames are not visible by web ui
alexandr.klimenko
Post by alexandr.klimenko »
Hi.
I have ZoneMinder 1.24.2 installed on Fedora11 (Linux version 2.6.29.4-167.fc11.i686.PAE (mockbuild@x86-5.fedora.phx.redhat.com) (gcc version 4.4.0 20090506 (Red Hat 4.4.0-4) (GCC) ) #1 SMP Wed May 27 17:28:22 EDT 2009)
Apache: Server version: Apache/2.2.13 (Unix) Server built: Aug 18 2009 06:16:17
In order to save disk space on server I mount events folder by cifs protocol on windows server 2008. Windows shared folder is mounted and accessible fine. ZoneMinder puts images there without any problem.
But when I try to view stored frames though web interface I see only blank instead of saved image.
Here are logs:
/var/log/messages
Dec 6 19:08:49 video zms[3523]: INF [Debug Level = 0, Debug Log = <none>]
Dec 6 19:08:49 video zms[3523]: INF [New Debug Level = 9, New Debug Log = /tmp/zm_debug.log.03523]
Dec 6 19:08:49 video zms[3523]: INF [Authenticated user 'vid']
Dec 6 19:08:50 video zmc_m22[2168]: INF [Dnepr_karavan: 5000 - Capturing at 1.00 fps]
Dec 6 19:08:51 video zma_m22[2180]: INF [Dnepr_karavan: 5000 - Processing at 1.00 fps]
Dec 6 19:08:55 video zms[3523]: INF [Got signal 15 (Terminated), exiting]
Dec 6 19:08:55 video zmdc[1941]: INF [Starting pending process, zmc -m 5]
Dec 6 19:08:55 video zmdc[1941]: INF ['zmc -m 5' starting at 10/12/06 19:08:55, pid = 3525]
Dec 6 19:08:55 video zmdc[3525]: INF ['zmc -m 5' started at 10/12/06 19:08:55]
Dec 6 19:08:55 video zmc_m5[3525]: INF [Debug Level = 0, Debug Log = <none>]
Dec 6 19:08:56 video zmc_m5[3525]: INF [Starting Capture]
Dec 6 19:08:59 video zmc_m5[3525]: ERR [Can't connect to remote camera: No route to host]
Dec 6 19:08:59 video zmc_m5[3525]: ERR [Unable to connect to camera]
Dec 6 19:08:59 video zmc_m5[3525]: ERR [Failed to pre-capture monitor 5 (0/1)]
Dec 6 19:08:59 video zmdc[1941]: ERR ['zmc -m 5' exited abnormally, exit status 255]
Dec 6 19:08:59 video zms[3527]: INF [Debug Level = 0, Debug Log = <none>]
Dec 6 19:08:59 video zms[3527]: INF [New Debug Level = 9, New Debug Log = /tmp/zm_debug.log.03527]
Dec 6 19:08:59 video zms[3527]: INF [Authenticated user 'vid']
Dec 6 19:09:01 video zmdc[1941]: INF [Starting pending process, zmc -m 16]
Dec 6 19:09:01 video zmdc[3529]: INF ['zmc -m 16' started at 10/12/06 19:09:01]
Dec 6 19:09:01 video zmdc[1941]: INF ['zmc -m 16' starting at 10/12/06 19:09:01, pid = 3529]
Dec 6 19:09:01 video zmc_m16[3529]: INF [Debug Level = 0, Debug Log = <none>]
Dec 6 19:09:01 video zmc_m16[3529]: INF [Starting Capture]
Dec 6 19:09:03 video zms[3527]: INF [Got signal 15 (Terminated), exiting]
/tmp/zm_debug.log.03608
12/06/10 19:13:07.088934 zms[3608].DB2-zm_monitor.cpp/3537 [Storing frame 2]
12/06/10 19:13:07.626646 zms[3608].DB3-zm_stream.cpp/115 [Scaling by 100, zooming by 100 = magnifying by 100(100)]
12/06/10 19:13:07.626738 zms[3608].DB3-zm_stream.cpp/119 [Last scaling by 100, zooming by 100 = magnifying by 100(100)]
12/06/10 19:13:07.626764 zms[3608].DB3-zm_stream.cpp/122 [Base image width = 480, height = 640]
12/06/10 19:13:07.626871 zms[3608].DB3-zm_stream.cpp/125 [Virtual image width = 480, height = 640]
12/06/10 19:13:07.626892 zms[3608].DB3-zm_stream.cpp/128 [Last virtual image width = 480, height = 640]
12/06/10 19:13:07.626911 zms[3608].DB3-zm_stream.cpp/131 [Actual image width = 480, height = 640]
12/06/10 19:13:07.626931 zms[3608].DB3-zm_stream.cpp/134 [Last actual image width = 480, height = 640]
12/06/10 19:13:07.626952 zms[3608].DB3-zm_stream.cpp/137 [Display image width = 480, height = 640]
12/06/10 19:13:07.626972 zms[3608].DB3-zm_stream.cpp/140 [Last display image width = 480, height = 640]
12/06/10 19:13:07.626992 zms[3608].DB3-zm_stream.cpp/143 [Send image width = 480, height = 640]
12/06/10 19:13:07.627012 zms[3608].DB3-zm_stream.cpp/146 [Last send image width = 480, height = 640]
12/06/10 19:13:07.627031 zms[3608].DB3-zm_stream.cpp/164 [Real image width = 480, height = 640]
12/06/10 19:13:07.730971 zms[3608].DB2-zm_monitor.cpp/3537 [Storing frame 3]
12/06/10 19:13:08.752803 zms[3608].DB3-zm_stream.cpp/115 [Scaling by 100, zooming by 100 = magnifying by 100(100)]
12/06/10 19:13:08.752888 zms[3608].DB3-zm_stream.cpp/119 [Last scaling by 100, zooming by 100 = magnifying by 100(100)]
12/06/10 19:13:08.752914 zms[3608].DB3-zm_stream.cpp/122 [Base image width = 480, height = 640]
12/06/10 19:13:08.752935 zms[3608].DB3-zm_stream.cpp/125 [Virtual image width = 480, height = 640]
12/06/10 19:13:08.752956 zms[3608].DB3-zm_stream.cpp/128 [Last virtual image width = 480, height = 640]
12/06/10 19:13:08.752975 zms[3608].DB3-zm_stream.cpp/131 [Actual image width = 480, height = 640]
12/06/10 19:13:08.752995 zms[3608].DB3-zm_stream.cpp/134 [Last actual image width = 480, height = 640]
12/06/10 19:13:08.753015 zms[3608].DB3-zm_stream.cpp/137 [Display image width = 480, height = 640]
12/06/10 19:13:08.753035 zms[3608].DB3-zm_stream.cpp/140 [Last display image width = 480, height = 640]
12/06/10 19:13:08.753054 zms[3608].DB3-zm_stream.cpp/143 [Send image width = 480, height = 640]
12/06/10 19:13:08.753074 zms[3608].DB3-zm_stream.cpp/146 [Last send image width = 480, height = 640]
12/06/10 19:13:08.753093 zms[3608].DB3-zm_stream.cpp/164 [Real image width = 480, height = 640]
12/06/10 19:13:08.785527 zms[3608].INF-zm_signal.cpp/43 [Got signal 15 (Terminated), exiting]
12/06/10 19:13:08.786834 zms[3608].DB2-zm_monitor.cpp/3537 [Storing frame 4]
12/06/10 19:13:09.314673 zms[3608].DB1-zm_monitor.cpp/3588 [Cleaning swap files from /tmp/zmswap-m23/zmswap-q755253]
/var/log/httpd/error_log
[Mon Dec 06 15:47:00 2010] [error] [client 195.138.218.200] array (\n 0 => \n array (\n 'file' => '/var/www/html/zm/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-096956s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/zm/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/html/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://91.201.39.248/zm/index.php?view=watch&mid=8
[Mon Dec 06 15:48:17 2010] [error] [client 195.138.218.200] File does not exist: /var/www/html/zm/events/18/91930, referer: http://91.201.39.248/zm/index.php?view= ... 930&fid=11
[Mon Dec 06 15:48:20 2010] [error] [client 195.138.218.200] File does not exist: /var/www/html/zm/events/18/91930, referer: http://91.201.39.248/zm/index.php?view= ... &scale=100
[Mon Dec 06 15:48:21 2010] [error] [client 195.138.218.200] File does not exist: /var/www/html/zm/events/18/91930, referer: http://91.201.39.248/zm/index.php?view= ... &scale=100
[Mon Dec 06 15:48:22 2010] [error] [client 195.138.218.200] File does not exist: /var/www/html/zm/events/18/91930, referer: http://91.201.39.248/zm/index.php?view= ... &scale=100
[Mon Dec 06 17:07:23 2010] [error] [client 195.138.218.200] PHP Notice: Undefined index: filter in /var/www/html/zm/skins/classic/views/js/filter.js.php on line 6, referer: http://91.201.39.248/zm/index.php?view=events&page=1
[Mon Dec 06 17:07:23 2010] [error] [client 195.138.218.200] PHP Notice: Undefined index: filter in /var/www/html/zm/skins/classic/views/js/filter.js.php on line 30, referer: http://91.201.39.248/zm/index.php?view=events&page=1
[Mon Dec 06 17:07:23 2010] [error] [client 195.138.218.200] PHP Notice: Undefined index: filter in /var/www/html/zm/skins/classic/views/filter.php on line 163, referer: http://91.201.39.248/zm/index.php?view=events&page=1
[Mon Dec 06 17:27:45 2010] [notice] caught SIGTERM, shutting down
[Mon Dec 06 17:30:18 2010] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Mon Dec 06 17:30:19 2010] [notice] Digest: generating secret for digest authentication ...
[Mon Dec 06 17:30:19 2010] [notice] Digest: done
[Mon Dec 06 17:30:19 2010] [notice] mod_python: Creating 4 session mutexes based on 256 max processes and 0 max threads.
[Mon Dec 06 17:30:19 2010] [notice] mod_python: using mutex_directory /tmp
[Mon Dec 06 17:30:19 2010] [notice] Apache/2.2.13 (Unix) DAV/2 PHP/5.2.9 mod_python/3.3.1 Python/2.6 mod_ssl/2.2.13 OpenSSL/0.9.8k-fips mod_perl/2.0.4 Perl/v5.10.0 configured -- resuming normal operations
[Mon Dec 06 17:31:51 2010] [notice] caught SIGTERM, shutting down
[Mon Dec 06 17:34:20 2010] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Mon Dec 06 17:34:20 2010] [notice] Digest: generating secret for digest authentication ...
[Mon Dec 06 17:34:20 2010] [notice] Digest: done
[Mon Dec 06 17:34:20 2010] [notice] mod_python: Creating 4 session mutexes based on 256 max processes and 0 max threads.
[Mon Dec 06 17:34:20 2010] [notice] mod_python: using mutex_directory /tmp
[Mon Dec 06 17:34:21 2010] [notice] Apache/2.2.13 (Unix) DAV/2 PHP/5.2.9 mod_python/3.3.1 Python/2.6 mod_ssl/2.2.13 OpenSSL/0.9.8k-fips mod_perl/2.0.4 Perl/v5.10.0 configured -- resuming normal operations
[Mon Dec 06 17:40:13 2010] [notice] caught SIGTERM, shutting down
[Mon Dec 06 17:42:32 2010] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Mon Dec 06 17:42:33 2010] [notice] Digest: generating secret for digest authentication ...
[Mon Dec 06 17:42:33 2010] [notice] Digest: done
[Mon Dec 06 17:42:33 2010] [notice] mod_python: Creating 4 session mutexes based on 256 max processes and 0 max threads.
[Mon Dec 06 17:42:33 2010] [notice] mod_python: using mutex_directory /tmp
[Mon Dec 06 17:42:33 2010] [notice] Apache/2.2.13 (Unix) DAV/2 PHP/5.2.9 mod_python/3.3.1 Python/2.6 mod_ssl/2.2.13 OpenSSL/0.9.8k-fips mod_perl/2.0.4 Perl/v5.10.0 configured -- resuming normal operations
[Mon Dec 06 17:45:57 2010] [error] [client 77.87.146.238] socket_sendto( /tmp/zms-879025s.sock ) failed: No such file or directory, referer: http://video.expressmanicure.com/index. ... tch&mid=29
[Mon Dec 06 17:45:57 2010] [error] [client 77.87.146.238] array (\n 0 => \n array (\n 'file' => '/var/www/html/zm/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-879025s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/zm/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/html/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://video.expressmanicure.com/index. ... tch&mid=29
[Mon Dec 06 17:46:02 2010] [error] [client 77.87.146.238] socket_sendto( /tmp/zms-879025s.sock ) failed: No such file or directory, referer: http://video.expressmanicure.com/index. ... tch&mid=29
[Mon Dec 06 17:46:02 2010] [error] [client 77.87.146.238] array (\n 0 => \n array (\n 'file' => '/var/www/html/zm/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-879025s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/zm/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/html/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://video.expressmanicure.com/index. ... tch&mid=29
/var/log/httpd/access_log
94.27.5.218 - - [06/Dec/2010:19:13:04 +0200] "GET /cgi-bin/nph-zms?mode=jpeg&monitor=23&scale=100&maxfps=5&buffer=1000&user=vid&connkey=755253&rand=1291655584 HTTP/1.1" 200 - "http://video.expressmanicure.com/index. ... tch&mid=23" "Mozilla/5.0 (Windows; U; Windows NT 5.1; ru; rv:1.9.2.12) Gecko/20101026 Firefox/3.6.12"
77.87.146.238 - - [06/Dec/2010:19:13:24 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:14:04 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:14:33 +0200] "POST /index.php HTTP/1.1" 200 880 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:14:44 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
195.138.218.200 - - [06/Dec/2010:19:14:52 +0200] "GET /zm/index.php HTTP/1.1" 200 115378 "http://91.201.39.248/zm/index.php" "Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.2.12) Gecko/20101027 Ubuntu/10.04 (lucid) Firefox/3.6.12"
77.87.146.238 - - [06/Dec/2010:19:15:24 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:16:04 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:16:44 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:17:25 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:17:30 +0200] "GET /index.php HTTP/1.1" 200 11556 "-" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:17:34 +0200] "POST /index.php HTTP/1.1" 200 880 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:18:05 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:18:45 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:19:25 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
195.138.218.200 - - [06/Dec/2010:19:19:56 +0200] "GET /zm/index.php HTTP/1.1" 200 115378 "http://91.201.39.248/zm/index.php" "Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.2.12) Gecko/20101027 Ubuntu/10.04 (lucid) Firefox/3.6.12"
77.87.146.238 - - [06/Dec/2010:19:20:05 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:20:34 +0200] "POST /index.php HTTP/1.1" 200 880 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:20:45 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:21:25 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:19:22:05 +0200] "POST /index.php HTTP/1.1" 200 164 "http://video.expressmanicure.com/index. ... tch&mid=29" "Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30618; AskTbBT3/5.9.1.14019)"
77.87.146.238 - - [06/Dec/2010:18:47:23 +0200] "GET /cgi-bin/nph-zms?mode=jpeg&monitor=29&scale=100&maxfps=5&buffer=1000&user=tochka&connkey=515453&rand=1291654040 HTTP/1.0" 200 - "-" "Cambozola V0.22"
195.138.218.200 - - [06/Dec/2010:19:22:34 +0200] "GET /zm/index.php?view=events&page=1&filter[terms][0][attr]=Archived&filter[terms][0][op]=%3D&filter[terms][0][val]=0&filter[terms][1][cnj]=and&filter[terms][1][attr]=DateTime&filter[terms][1][op]=%3E%3D&filter[terms][1][val]=-7+day&filter[terms][2][cnj]=and&filter[terms][2][attr]=MonitorId&filter[terms][2][op]=%3D&filter[terms][2][val]=11 HTTP/1.1" 200 18947 "http://91.201.39.248/zm/index.php" "Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.2.12) Gecko/20101027 Ubuntu/10.04 (lucid) Firefox/3.6.12"
195.138.218.200 - - [06/Dec/2010:19:22:37 +0200] "GET /zm/index.php?view=frames&eid=92006 HTTP/1.1" 200 31080 "http://91.201.39.248/zm/index.php?view= ... 2][val]=11" "Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.2.12) Gecko/20101027 Ubuntu/10.04 (lucid) Firefox/3.6.12"
195.138.218.200 - - [06/Dec/2010:19:22:39 +0200] "GET /zm/index.php?view=frame&eid=92006&fid=1 HTTP/1.1" 200 1878 "http://91.201.39.248/zm/index.php?view=frames&eid=92006" "Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.2.12) Gecko/20101027 Ubuntu/10.04 (lucid) Firefox/3.6.12"
195.138.218.200 - - [06/Dec/2010:19:22:40 +0200] "GET /zm/events/11/92006/001-capture.jpg HTTP/1.1" 200 144832 "http://91.201.39.248/zm/index.php?view= ... 2006&fid=1" "Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.2.12) Gecko/20101027 Ubuntu/10.04 (lucid) Firefox/3.6.12"
195.138.218.200 - - [06/Dec/2010:19:22:40 +0200] "GET /zm/events/11/92006/001-capture.jpg HTTP/1.1" 206 144832 "http://91.201.39.248/zm/index.php?view= ... 2006&fid=1" "Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.2.12) Gecko/20101027 Ubuntu/10.04 (lucid) Firefox/3.6.12"
