keep zoneminder record for 1 month
Hi, I have been trying to find out how can I keep the zoneminder record for 1 month, does anyone know? Thank you.
sure, I have 3 cameras attached to zoneminder and running 24x7. (I have 1 tb gig hard drive). I would like the zoneminder to delete all the events every month and starts fresh. Is this somethng that I can do w/ the filter stuff you mentioned? If so, can you pls let me know where is that in the UI? Thank you.
Just like Flash_ said... if you want to start 'fresh' as you put it, it's easy.. just need to delete all events. For example.sejay wrote:sure, I have 3 cameras attached to zoneminder and running 24x7. (I have 1 tb gig hard drive). I would like the zoneminder to delete all the events every month and starts fresh. Is this somethng that I can do w/ the filter stuff you mentioned? If so, can you pls let me know where is that in the UI? Thank you.
echo "delete from Events where 1" | mysql -u<dbuser> -p<dbpass> zm
zmaudit.pl
Stick that in a cron job to run every month and you're good to go. Don't recommend this particularly however since it will start 'fresh', and anything significant that happens right before the deletion will likely be missed. Could setup a daily cron-job to delete a 1 month window as an alternative.
eyeZm, Native iPhone App for ZoneMinder: http://www.eyezm.com
Version 1.3 now available on iTunes, introduces Montage view, HTTPS/SSL support and H264 native streaming!
Subscribe to RSS feed for updates: http://www.eyezm.com/rssfeed.xml
Hi sejay,sejay wrote:sure, I have 3 cameras attached to zoneminder and running 24x7. (I have 1 tb gig hard drive). I would like the zoneminder to delete all the events every month and starts fresh. Is this somethng that I can do w/ the filter stuff you mentioned? If so, can you pls let me know where is that in the UI? Thank you.
Is there any particular reason you need to remove all the files and start fresh each 30 days? Through another board discussion on here (don't feel like hunting) I set up a filter so that anything over X days is auto-deleted from the system because I need to maintain 95 days worth of footage at all times.
Steps:
1. open filter window
2. First field "Use Filter" leave set to "Choose Filter"
3. Second field set to "Date/Time"
4. Third field set to "Less than"
5. Fourth Field set to " -30 day " (without quotes)
6. Click the "+" to add another parameter line
7. Fifth field set to "and"
8. Sixth field set to "Archive Status"
9. Seventh field "Unarchived Only"
10. Set "Sort by" to "Id" and "Asc"
11. Set "Limit to first "20" results only"
12. Select "Delete all matches" check box
13. Click "Save"
14. Assign the filter a name
15. Select "Run filter in background"
16. Save.
Its a very simple way to keep things from growing out of control and maintain a set number of days.
Ryan
