no image with swf stream
Posted: Wed Dec 08, 2010 7:26 pm
We are running zm 1.24.2 on ubuntu 10.10 installed from the Zoneminder Install DVD.
We use two logitech C500 usb cams each connected to a seperate internal card.
When we use a resolution of 320x240px and set the stream-format to swf everything works fine and we can see the stream in monitor mode.
So we tried with a higher resolution (640x480) But this didnt work. We disconnected one cam and changed stream-format to asf.
Everything ok we have a live picture.
Changing the format to swf nothing. No not nothing, the monitor window pops up no picture just a white screen.
On the bottom of the monitor window you can see the text "idle - 5.02 frames/s ". (same with 1 fps)
So we turned on debugging and searched in the messages but everything seems ok no errors or warnings.
We have tried different Browsers (IE, FF, Chrome) on different machines all with the same problem - just white picture with status text. cpu load ist about 0.14.
here is the output of messages:
Maybe its a problem with ffmpeg, we left the input and output options to the default
If we missed some info please let us know.
Thanks in advance.
wutzen zmpkg[1863]: INF [Command: start]
Dec 8 18:48:39 wutzen zmfix[1943]: INF [New Debug Level = 2, New Debug Log = /tmp/zm_debug.log.01943]
Dec 8 18:48:39 wutzen zmfix[1943]: INF [Resetting permissions on /dev/video1 to 20666]
Dec 8 18:48:39 wutzen zmdc[1947]: INF [Server starting at 10/12/08 18:48:39]
Dec 8 18:48:42 wutzen zmdc[1947]: INF ['zmc -d /dev/video1' starting at 10/12/08 18:48:42, pid = 2087]
Dec 8 18:48:42 wutzen zmdc[2087]: INF ['zmc -d /dev/video1' started at 10/12/08 18:48:42]
Dec 8 18:48:42 wutzen zmc_dvideo1[2087]: INF [Debug Level = 0, Debug Log = <none>]
Dec 8 18:48:42 wutzen zmc_dvideo1[2087]: INF [New Debug Level = 2, New Debug Log = /tmp/zm_debug.log.02087]
Dec 8 18:48:42 wutzen zmc_dvideo1[2087]: INF [Starting Capture]
Dec 8 18:48:42 wutzen zmc_dvideo1[2087]: INF [Brightness 2 128]
Dec 8 18:48:42 wutzen zmdc[1947]: INF ['zmfilter.pl' starting at 10/12/08 18:48:42, pid = 2090]
Dec 8 18:48:42 wutzen zmdc[2090]: INF ['zmfilter.pl' started at 10/12/08 18:48:42]
Dec 8 18:48:42 wutzen zmc_dvideo1[2087]: INF [Brightness 3 128]
Dec 8 18:48:42 wutzen zmc_dvideo1[2087]: WAR [Hue control is not suppported]
Dec 8 18:48:42 wutzen zmdc[1947]: INF ['zmaudit.pl -c' starting at 10/12/08 18:48:42, pid = 2094]
Dec 8 18:48:42 wutzen zmdc[2094]: INF ['zmaudit.pl -c' started at 10/12/08 18:48:42]
Dec 8 18:48:42 wutzen zmfilter[2090]: INF [Scanning for events]
Dec 8 18:48:42 wutzen zmdc[1947]: INF ['zmwatch.pl' starting at 10/12/08 18:48:42, pid = 2097]
Dec 8 18:48:42 wutzen zmdc[2097]: INF ['zmwatch.pl' started at 10/12/08 18:48:42]
Dec 8 18:48:42 wutzen zmwatch[2097]: INF [Watchdog starting]
Dec 8 18:48:42 wutzen zmwatch[2097]: INF [Watchdog pausing for 30 seconds]
Dec 8 18:48:42 wutzen zmdc[1947]: INF ['zmupdate.pl -c' starting at 10/12/08 18:48:42, pid = 2101]
Dec 8 18:48:42 wutzen zmdc[2101]: INF ['zmupdate.pl -c' started at 10/12/08 18:48:42]
Dec 8 18:52:03 wutzen zmc_dvideo1[2087]: INF [Wutzen_oben: 1000 - Capturing at 4.98 fps]
Dec 8 18:55:23 wutzen zmc_dvideo1[2087]: INF [Wutzen_oben: 2000 - Capturing at 5.00 fps]
Dec 8 18:58:44 wutzen zmc_dvideo1[2087]: INF [Wutzen_oben: 3000 - Capturing at 4.98 fps]
Dec 8 19:02:04 wutzen zmc_dvideo1[2087]: INF [Wutzen_oben: 4000 - Capturing at 5.00 fps]
Dec 8 19:03:09 wutzen zmpkg[3380]: INF [Command: stop]
Dec 8 19:03:09 wutzen zmdc[1947]: INF ['zmaudit.pl -c' stopping at 10/12/08 19:03:09]
Dec 8 19:03:09 wutzen zmdc[1947]: INF ['zmaudit.pl -c' exited, signal 14]
Dec 8 19:03:09 wutzen zmdc[1947]: INF ['zmupdate.pl -c' stopping at 10/12/08 19:03:09]
Dec 8 19:03:09 wutzen zmdc[1947]: INF ['zmupdate.pl -c' exited, signal 14]
Dec 8 19:03:09 wutzen zmdc[1947]: INF ['zmwatch.pl ' stopping at 10/12/08 19:03:09]
Dec 8 19:03:09 wutzen zmdc[1947]: INF ['zmwatch.pl ' exited, signal 14]
Dec 8 19:03:09 wutzen zmdc[1947]: INF ['zmfilter.pl ' stopping at 10/12/08 19:03:09]
Dec 8 19:03:09 wutzen zmdc[1947]: INF ['zmfilter.pl ' exited, signal 14]
Dec 8 19:03:09 wutzen zmdc[1947]: INF ['zmc -d /dev/video1' stopping at 10/12/08 19:03:09]
Dec 8 19:03:09 wutzen zmc_dvideo1[2087]: INF [Got signal 15 (Terminated), exiting]
Dec 8 19:03:09 wutzen zmdc[1947]: INF ['zmc -d /dev/video1' exited normally]
Dec 8 19:03:19 wutzen zmdc[1947]: INF [Server shutdown at 10/12/08 19:03:19]
Thanks in advance.
