OS Linux 2.6.34.7-63.fc13.i686
ZM v1.24.2 via yum install [erase,install,erase,install...]
/proc/sys/kernel/shmall 134217728, shmmax 134217728
zmwatch[20710].ERR [Can't get shared memory id
also: zmcd: zmc exit abnormally, status 30
I've Googled & searched and run out of things to try.
Please...............
Another Can't get shared memory id
I doubled shmall/max to 268435456 and rebuilt the DB. Which leads me to another question. The load has the zm_create file and 37 update files. But after I install the base DB and start running the updates I get errors on every one and when I'm done WarmUpCount is missing from the Monitors table. So my new question is: should I run the single create and all of the updates or just the create.sql file?
By running just the create.sql file the web page now displays a blank/broken image but I still don't get shared memory.
TA-DA (5 min later) I'm up and running. Having added "drop database if exists zm;" to the create script and NOT running any updates.
I have a question...why did you rebuilt the database when changing the shared memory settings?. Is there any specific reason to do that?
How many cameras has your system? Resolutions? FPS? RAM?
I ask you this because I have set my system (2 ipcams, 320x240, 3pfs, 512Mbytes), with very small image buffer size, and I wanted to know if people with similar systems have different shared memory settings.
Thanks in advance,
PacoLM
Thanks in advance,
PacoLM
I rebuilt the DB because I remembered errors when I created it for the first time - must digress -
/usr/share/zoneminder/db has 1 zm_create.sql and 37 updates.sqls. My background says load the base code and then apply the updates - otherwise they wouldn't be any reason for those [updates] to be included in the RPM. What I remembered was: complaint, error, error, missing, error... for just about every update file. When I decided to reload was when I found the DB didn't have a WarmUpCount column.
I had doubled the 2 shm*** values - didn't fix it. So I took a WAG the "Can't get shared memory id" was because the DB was foobar and reloaded it - sans 37 updates - and wonder of wonders.
So, I'm going out on a limb here and say - "When you download ZM and create the DB - DO NOT load the update.sql files - rm *update* as the very first step".
C
Cams: Axis 2100, Axis 206W, Venus USB (china via ebay) and a couple of X10 (in the closet). Oh, my shm's are 268M - ipcs says each cam is using 36M of memory - 640x480. I think I can trim that back just a bit....
C
