rs 232 and zoneminder
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
Qvagin
Post by Qvagin »
Hello developer zoneminder!
You can add the option - to issue a RS-232 port any code depending on the event system.
For example - the issue at the port F0 if detected motion in the video camera at No. 1.
I ask you about it, because automation X10 here in Ukraine are very expensive.
I do programming PIC MICROCONTROLLER and the inclusion of this option greatly expanded opportunities zoneminder with various automation systems houses, both with industry and improvised.
Also it will help popularize video surveillance and security based on Linux in Ukraine.
kingofkya
Post by kingofkya »
look in the zmfilter.pl its easy to control serial ports however you will have to setup filter to trigger them.
Also X10 is a glorified modem so with a little effort you might be able to just use the X10 suport. Happy Hacking:)
