--119e0e4f-A--
[19/Dec/2010:12:49:30 --0500] TQ5Fqn8AAAEAAA4IeQgAAAAE <WAN> 51620 192.168.0.2 80
--119e0e4f-B--
POST /zm/index.php HTTP/1.1
Host: www.
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 6.1; en-US; rv:1.9.2.13) Gecko/20101203 Firefox/3.6.13
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-us,en;q=0.5
Accept-Encoding: gzip,deflate
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive: 115
Connection: keep-alive
Referer:
http://www.
Cookie: zmMontageLayout=montage_2wide.css; zmBandwidth=high; replayMode=all; zmSkin=classic; ZMSESSID=s73gsfkctvn34ntksmcr4ajji6
Content-Type: application/x-www-form-urlencoded
Content-Length: 1270
--119e0e4f-C--
view=monitor&tab=source&action=&mid=5&newMonitor%5BLinkedMonitors%5D=&origMethod=v4l2&newMonitor%5BDevice%5D=%2Fdev%2Fvideo2&newMonitor%5BChannel%5D=0&newMonitor%5BFormat%5D=45056&newMonitor%5BProtocol%5D=&newMonitor%5BHost%5D=&newMonitor%5BPort%5D=80&newMonitor%5BMethod%5D=v4l2&newMonitor%5BPath%5D=&newMonitor%5BPalette%5D=1329743698&newMonitor%5BWidth%5D=640&newMonitor%5BHeight%5D=480&newMonitor%5BOrientation%5D=0&newMonitor%5BLabelFormat%5D=%25N+-+%25y%2F%25m%2F%25d+%25H%3A%25M%3A%25S&newMonitor%5BLabelX%5D=0&newMonitor%5BLabelY%5D=0&newMonitor%5BImageBufferCount%5D=50&newMonitor%5BWarmupCount%5D=25&newMonitor%5BPreEventCount%5D=50&newMonitor%5BPostEventCount%5D=120&newMonitor%5BStreamReplayBuffer%5D=20&newMonitor%5BAlarmFrameCount%5D=12&newMonitor%5BEventPrefix%5D=Event-&newMonitor%5BSectionLength%5D=3600&newMonitor%5BFrameSkip%5D=0&newMonitor%5BFPSReportInterval%5D=1000&newMonitor%5BDefaultView%5D=Events&newMonitor%5BDefaultRate%5D=100&newMonitor%5BDefaultScale%5D=100&newMonitor%5BWebColour%5D=red&newMonitor%5BSignalCheckColour%5D=%230100BE&newMonitor%5BName%5D=Play_Area&newMonitor%5BType%5D=Local&newMonitor%5BFunction%5D=Mocord&newMonitor%5BEnabled%5D=1&newMonitor%5BMaxFPS%5D=0.50&newMonitor%5BAlarmMaxFPS%5D=15.00&newMonitor%5BRefBlendPerc%5D=5
--119e0e4f-F--
HTTP/1.1 403 Forbidden
Content-Length: 295
Connection: close
Content-Type: text/html; charset=iso-8859-1
--119e0e4f-H--
Message: Pattern match "^([^;\s]+)" at REQUEST_HEADERS:Content-Type. [file "/etc/httpd/modsecurity.d/base_rules/modsecurity_crs_30_http_policy.conf"] [line "63"] [id "960010"] [msg "Request content type is not allowed by policy"] [data "application/x-www-form-urlencoded"] [severity "WARNING"] [tag "POLICY/ENCODING_NOT_ALLOWED"] [tag "WASCTC/WASC-20"] [tag "OWASP_TOP_10/A1"] [tag "OWASP_AppSensor/EE2"] [tag "PCI/12.1"]
Message: Pattern match "([^*:\s\w,.\/?+-]\s*)?(?<![a-z]\s)(?<a>\|])(\s*return\s*)?(?:globalstorage|sessionstorage|postmessage|callee|constructor|content|domain|prototype|try|catch|top|call|apply|url|function|object|array|string|math|if|elseif|case|switch|regex|boolean|l ..." at ARGS_NAMES:newMonitor[Function]. [file "/etc/httpd/modsecurity.d/base_rules/modsecurity_crs_41_phpids_filters.conf"] [line "66"] [id "900020"] [msg "Detects JavaScript language constructs"] [data "[function]"] [severity "CRITICAL"] [tag "WEB_ATTACK/XSS"] [tag "WEB_ATTACK/CSRF"] [tag "WEB_ATTACK/ID"] [tag "WEB_ATTACK/RFE"]
Message: Pattern match "(?:%c0%ae\/)|(?:(?:\/|\\)(home|conf|usr|etc|proc|opt|s?bin|local|dev|tmp|kern|[br]oot|sys|system|windows|winnt|program|%[a-z_-]{3,}%)(?:\/|\\))|(?:(?:\/|\\)inetpub|localstart\.asp|boot\.ini)" at ARGS:newMonitor[Device]. [file "/etc/httpd/modsecurity.d/base_rules/modsecurity_crs_41_phpids_filters.conf"] [line "86"] [id "900011"] [msg "Detects specific directory and path traversal"] [data "/dev/"] [severity "CRITICAL"] [tag "WEB_ATTACK/DT"] [tag "WEB_ATTACK/ID"] [tag "WEB_ATTACK/LFI"]
Message: Pattern match "([^*:\s\w,.\/?+-]\s*)?(?<![a-z]\s)(?<a>\|])(\s*return\s*)?(?:hash|name|href|navigateandfind|source|pathname|close|constructor|port|protocol|assign|replace|back|forward|document|ownerdocument|window|self|parent|frames|_?content|date|cookie|inner ..." at ARGS_NAMES:newMonitor[Protocol]. [file "/etc/httpd/modsecurity.d/base_rules/modsecurity_crs_41_phpids_filters.conf"] [line "191"] [id "900017"] [msg "Detects JavaScript object properties and methods"] [data "[protocol]"] [severity "CRITICAL"] [tag "WEB_ATTACK/XSS"] [tag "WEB_ATTACK/CSRF"] [tag "WEB_ATTACK/ID"] [tag "WEB_ATTACK/RFE"]
Message: Pattern match "([^*:\s\w,.\/?+-]\s*)?(?<![a-z]\s)(?<a>\|])(\s*return\s*)?(?:hash|name|href|navigateandfind|source|pathname|close|constructor|port|protocol|assign|replace|back|forward|document|ownerdocument|window|self|parent|frames|_?content|date|cookie|inner ..." at ARGS_NAMES:newMonitor[Port]. [file "/etc/httpd/modsecurity.d/base_rules/modsecurity_crs_41_phpids_filters.conf"] [line "191"] [id "900017"] [msg "Detects JavaScript object properties and methods"] [data "[port]"] [severity "CRITICAL"] [tag "WEB_ATTACK/XSS"] [tag "WEB_ATTACK/CSRF"] [tag "WEB_ATTACK/ID"] [tag "WEB_ATTACK/RFE"]
Message: Pattern match "([^*:\s\w,.\/?+-]\s*)?(?<![a-z]\s)(?<a>\|])(\s*return\s*)?(?:hash|name|href|navigateandfind|source|pathname|close|constructor|port|protocol|assign|replace|back|forward|document|ownerdocument|window|self|parent|frames|_?content|date|cookie|inner ..." at ARGS_NAMES:newMonitor[Name]. [file "/etc/httpd/modsecurity.d/base_rules/modsecurity_crs_41_phpids_filters.conf"] [line "191"] [id "900017"] [msg "Detects JavaScript object properties and methods"] [data "[name]"] [severity "CRITICAL"] [tag "WEB_ATTACK/XSS"] [tag "WEB_ATTACK/CSRF"] [tag "WEB_ATTACK/ID"] [tag "WEB_ATTACK/RFE"]
Message: Pattern match "(?:[+\/]\s*name[\W\d]*[)+])|(?:;\W*url\s*=)|(?:[^\w\s\/?:>]\s*(?:location|referrer|name)\s*[^\/\w\s-])" at ARGS_NAMES:newMonitor[Name]. [file "/etc/httpd/modsecurity.d/base_rules/modsecurity_crs_41_phpids_filters.conf"] [line "311"] [id "90004"] [msg "Detects url-, name-, JSON, and referrer-contained payload attacks"] [data "[name]"] [severity "CRITICAL"] [tag "WEB_ATTACK/XSS"] [tag "WEB_ATTACK/CSRF"]
Message: Access denied with code 403 (phase 2). [file "/etc/httpd/modsecurity.d/base_rules/modsecurity_crs_49_enforcement.conf"] [line "25"] [msg "Anomaly Score Exceeded (score 26): 90004-Detects url-, name-, JSON, and referrer-contained payload attacks"]
Action: Intercepted (phase 2)
Apache-Handler: php5-script
Stopwatch: 1292780970265067 55360 (1812* 54944 -)
Producer: ModSecurity for Apache/2.5.12 (
http://www.modsecurity.org/); core ruleset/2.0.5.
Server: Apache/2.2.15 (Fedora)
--119e0e4f-Z--
